Longer Rear center brake hose needed
bronco loco
It never ends
Long Island New York
We lifted the rear 2.5, and now the rear hose that comes down from the frame to the center of the axle is stretched out. Anyone knows a part number for a hose that may be about three inches longer that can be purchased in a local store? Thanks in advance.
RedBank
I'll ask you first....are you talking about break line or the rear axle vent tube?
Sent from my SM-G781V using Tapatalk
I know the late 70s truck came in 2 lengths. I put a 4wd on my 2wd truck as it was 2" longer to match the 2" lift. Rockauto publishes lengths sometimes in the detailed specs.
Jedeka
I think I have an extra braided brake hose, if you are interested.
Rustytruck
you can use the longer line from the 78-79 ford bronco. you can also space up the Brake line block and metal lines off the axle housing. that's how Rancho did it back in the day with a simple metal strap to space it up.
