Cooter_76
- May 18, 2004
- 863
Now that my Explorer 5.0/4R70W is up and running, I need to address the axles & tires. Just starting to dip into the planning stages now, and looking for some guidance.
Bronco currently has 2.5” suspension lift, 1” body lift, 32 x 11.50 BFG KM2’s on 15 x 8 aluminum wheels. Tires are at least 11 years old. Rear fenders are cut, with old-school flares. Front fenders are uncut. Axles are original Dana 44 up front and small bearing 9” in the rear with 3.50 gears & limited slips in both (and I think they’ve reached their “limit.”)
I’m 90% sure I’ll wind up with 33 x 10.50 tires. I can’t see myself going so far as to really need 35” tires. 35’s would also require more fender trimming and might be harder on other components (steering, etc?) I do plan to eventually cut the front fenders, regardless. I like the look of 33 x12.50, but would probably prefer the street manners of the 10.50. I better stop there, or I’ll wind-up talking myself into a Prius.
According to the door sticker on the Explorer, it had 3.73 gears and 235/75R15s. So the engine would be turning 2126 RPM at 70 MPH. Assuming I go with 33" tires, here are the theoretical RPMs at 70 MPH with a given diff gear:
4.10 gears - 2046 RPM
4.30 gears - 2145 RPM
4.56 gears - 2275 RPM
Based on that, it seems like 4.56 would put the engine operating pretty close to where it was designed to run, and account for the heavier tires. But would 4.88's be better?
So I need new gears, and like the idea of a gear-driven limited slip (TrueTrac.) Probably a good idea to step up to 31 spline axles. Any issues using the adapter bearings with a small-bearing housing? Would new 28 spline axles suffice? I seem to remember a thread recently where people were talking about how weak the small bearing housings are.
Window-shopping on WH’s site, it looks like I can get a built third member with Yukon gears and a TrueTrac for $1801, plus $325 for new axle shafts. Didn’t see the bearings on their site.
Then I see that Speedway Motors has a complete fabricated housing with gear type posi, fully built third member and new axle shafts for $1699. Am I reading this right? Would it basically just need spring perches and new brakes?
I haven’t started thinking about the front axle yet. Wanted to make sure I’m headed down the right path.
