I replaced the mechanical and still have fuel pressure issues. Only getting about half what I need. Last one didn't hold up to ethanol in the fuel either.I'd just run a good mechanical pump for your set-up. I got an electric carter 4070 fuel pump because explorer timing cover doesn't have a fuel pump mount.
All new everything. From tank to lines were the first things I replaced when restoring it. Nothing over 2 years old. Even replaced the carb. It's just not consistently getting enough fuel. But I'm open to any all suggestions. I just want it running and not sitting.What is the condition of all of your hoses? They could be the problem. If you haven't replaced them recently I would do so and use Emission Barrier hose. That stuff is not inexpensive, but it does have a liner in it that modern "gasoline" won't degrade.
What does the fuel sock on the end of the pick-up in the tank look like? I had one of those break up and clog the pick-up.
Just spitballing, but could you have a venting issue on the fuel tank?All new everything. From tank to lines were the first things I replaced when restoring it. Nothing over 2 years old. Even replaced the carb. It's just not consistently getting enough fuel. But I'm open to any all suggestions. I just want it running and not sitting.
