flani33
I recently changed spark plugs put in new collector gaskets and manifold gaskets to fix some leaks. The engine backfired very loudly during the first test drive. Drove it the next day 50 miles and it was fine. It happened again the day after and since my right ear was ringing I think it was the passenger side out of true duals with stock manifolds.
Pulled the plugs, checked the gaps at .40, checked firing order and that was all fine. Drove the next 2 days with no problem. It seems to backfire if i'm dogging it around town because it happened again today. It idles well as far as I'm concerned and has never backfired like this before.
I assume a cylinder isn't firing and I plan to check the points. It seems easy to say that I caused this problem or the changes have shown an underlying problem. I put in same plugs that i took out. Any advice would be helpful. Thanks
351w, holley 600
351w, holley 600
