- Nov 11, 2007
- 8,223
well, sounds like a $1,000 well spent if the world of valve train has gone to crap.
Did a little browsing earlier and someone had posted about checking a lifter or can with a file. Supposedly the file shouldn’t affect them as iit’s Rockwell C is lower than the hardened surfaces. I have my doubts about how accurate this would be…..but maybe there are heat treat problems out there?I am hoping I can disassemble mine & inspect b4 I install.
dodge as well with hemi.Remember, brand new Chev engines are having all kinds of lifter issues on their V8's with their fancy - on/off lifters.![]()
Forgot to answer this Lars-yes, the roller rotates freely. Definitely not the needles but the actual face of the roller itself (or cam lobe).^^^this. A roller lifter should roll on the lobe with 3 in 1 oil. That lifter has probably been eating itself practically since it was installed. Does the remains of the roller spin freely? Can you see what the cam lobe looks like? Not that I expect it to look shiny new.
Those are known to die if you idle too much. Not the fancy ones either, just regular rollers. Prevailing theory is there isn't enough splash oil at idle. Way to go Dodge, splash oil lubed lifters.dodge as well with hemi.
they are saying same thing about jeeps 3.6 v6, company says its made to rev, thats how top end oils, they do not understand why people are not hitting 5,500rpm more often.Those are known to die if you idle too much. Not the fancy ones either, just regular rollers. Prevailing theory is there isn't enough splash oil at idle. Way to go Dodge, splash oil lubed lifters.
Well, someone has to scare the deer off the roads!So if I hear all you guys clearly, you're telling me & everybody else that I should be buzzing to 6K rpm repeatedly while going to town for groceries, bolts, irrigation supplies right??
Come on in........ Join the "cool kids club"So if I hear all you guys clearly, you're telling me & everybody else that I should be buzzing to 6K rpm repeatedly while going to town for groceries, bolts, irrigation supplies right??
