Colorado75Bronc
i'd reccomend no bigger than 35's if your gonna stick with stock bronco axles, and prolly a 3.5" lift and alot of cutting, im running fw's under mine, 3.5" lift, 2" body lift, a N.P.435, dana 20 t-shift t-case, currently 33's, and plan on running 35's and a detroit true-trac in the rear and a detroit locker in the front as it is still a daily driver, i just actually finished the fullwidth rear, and im gettin started on the front, just can't afford to buy the steel and tie rod ends to build my oneton steering, with in the next couple weeks i'll post the pics of the swap when i get the front high pinion fw d44 in. but you can run some pretty tough trails on 35's, i live in colorado and know you can do the majority of the trails here on them, there's a couple that would be a hell of a challenge, but doable
