Ok, today I finally got the new studs and poly-nuts on order. So that bring the price on this fix to about $580 now. Which in retrospect is pretty disappointing. I think I have thrown about $1800 at this motor since it was rebuilt last year (msd, card stuff, o2 sensor, electronic ignition, new alternator for 95 mustang, more msd stuff, and more carb stuff). I hope this girl decides she finally got what wanted. Because not happy by Monday of next week she's going to the junk yard and I'm going back to riding the bike.
I will be happy when she is happy, but I will also be be pissed if it turn out it was the cam all along.
You may want to put out feelers for a fellow bronco owner that has some engine experiance in your area. They may be able to helpp you understand some of what you are being told here. Really not trying to bag on you at all but trying to make you understand some of the ins and outs.I have the original 289 heads stock, w/ brand new rocker Arms, they had studs (7/16-20)
stock 289 heads dont have 7/16 studs
I have GT40 heads stock from 96 Ford
Explorer, with pedestal style rocker
Arms, with 3/8-16 bolts
Gt40 and all other pedestal mount rockers use 5/16" bolts
I was going to have the GT40 heads bored and tapped for new studs that were direct replacement of the studs on the 289 heads. That way the GT40 heads would have rocker arms on them that are exact same hight on the push-rods, and l already know the valves where the say hight when i had them on the bench. So I don't know why this won't work.
Not going to say it wont work but the whole reason for installing studs is to gain adjustabilty and with adjustable type rocker arms guide plates and hardened pushrods are needed. Now if you have whats called rail rocker arms well they are not well suited for adjustable setups. you may get interferance with the valve retainers and could actually drop a valve with high lift cams. Usually when installing studs in pedestal heads you have to get the pedastal mounts machined down I want to say .320 or so. It doesnt matter if you have adjustable rockers or not valve train geometery is controlled by the pushord lenght. If your pushrod is to short or long then you will side load the valves and cause excessive wear and may also endup bending pushrods and or collasping lifters or wearing down a cam lobe due to the extra leverage/friction involved
Now, The direct replacement studs for the Mark V are, 7/16-20 on the top, and 3/8-16 on the bottom. The only difference is that they are .30" shorter (never used the top 3/8" of the studs anyways.) I would have gotten the guide plates but u only need guide plates for roller rockers (some other day.)
Not sure what your talking about here with the mark V must have missed that somewhere. but guide plates are not only for roller rockers. they are for adjustable rockers period. unless your heads have slotted pushrod holes as HiPo 289 heads did have. but you still need hardened pushrods.
At this point in the game, I feel like I have everyone in the world telling me what is wrong with the truck but no one has any real solutions. bcm69 has made the most since so far. 9* advance is way to much. (I did ask in the forum several times, "which is better, longer push-rods or bore, tap, w/ new studs)
I can appreciate your frustrations but I dont think you are really listening to what people are suggesting. While you have asked questions you need to actually check out the suggestions before you just run off and buy parts to throw at the issue. There is almost always more than one single answer and there is not nessearily a which is better when you main problem seems to be pushrod lenght.
And lastly, if I could afford a mechanic that knew what he was doing, I would leave it with him until i was fully satisfied. But with a new baby...
Thank to everyone for you input. I always invite all of your comments, good or bad. I am always learning something new from it.
It was the cam.
I would look to Lunati to see if this cam is supposed to be stabbed straight up & down, or if it's designed to be advanced. (I bought a lunati blower cam once, at a swap meet, installed it in my '93 notchback mustang, 302 w/ AFR 185's, Holley systemax intake & Vortech V-1 @ 14#- it was a turd 'til 4K, then it came ALIVE. Turns out the cam needed to be installed w/ 4* advance)
