lower radiator hose - no spring?
Mark
Bronco Klutz
NW Indiana
Putting a new lower radiator hose on, and the new one does not have a spring to keep it from collapsing under vacuum pressure.
Is this no longer a concern?
Yeller
Rogers County Oklahoma
Not if your running a purge tank instead of an over flow. Purge tank purges air from the radiator and an over flow just catches the what over flows. Over flow tank allows air in the system that can creat vacuum.
Mark
Mark
Bronco Klutz
NW Indiana
okay thanks, that makes sense. No purge tank, I guess I'll take another trip to the hardware store for a spring. :)
Yeller
Add a purge tank, your cooling system will thank you.
All that being said I really don’t think the spring is that important. I’ve not built anything in the last 25 years with a spring and never an issue.
I've had plenty of lower hoses without the spring. They have worked fine for me. My understanding is the spring is a crutch when a hose is too soft. I'll even go so fat as to say it has been decades since I have seen (a new) hose with the spring in it.
