My Bronco build is progressing very slow but steady- entire front end is off now and all body panels being replaced. While the front end is open and engine accessible I am cleaning and touching up the 302 engine with paint, checking all hoses and clamps and just replaced the lower radiator hose with a new one from TBP. It previously had a universal coil style hose, worn out and ready to break. The new one is formed to fit with the coil spring inside. It's a very tight fit- it snakes under the alternator bracket and rests against the frame. There is very little clearance for the fan- only about 1/4-1/2 inch depending how much I crunch up the hose. I have not installed the radiator just yet and I am afraid that if the hose needs to stretch even a little out towards the radiator it will hit the fan. Is this normal? Is perhaps my fan too big in diameter? And is it OK that the hose rests against the front frame cross member?
