LOWERING my Bronco
greatguy57078
greatguy57078
I like that idea also. I ordered magnets at work not long ago, and they were VERY strong. You had to slide them off and they were very small diameter. Some of them in there catalog had a warning by the description that said to be careful as you did not want to have your skin get between the magnet and any metalic object. I am really going to look into this now. Great idea Heuss33! I will let you know what I come up with now!
Heus33
If not magnets, how bout clips that secure behind the slats in the grille?
Magnets might scratch and could fly off at speed - im sure there's a good solution out there. I'll keep the ol noggin workin for ya.
greatguy57078
greatguy57078
I checked out a place that does galvanized dipping for the frame, possibly the tub. They have a "kettle" that is 31' x 5' x 6' deep. They got back to me today and it is only .36 a pound and you can have anything dipped that will fit in the kettle. He did say something about warpage, but I will have to ask more questions before I make the trip there.That sounds pretty reasonable to me!
greatguy57078
greatguy57078
My son and I got the frame hauled over to the shop that we will be working in. My friend from work built his 34 Ford coupe frame using rails that he bought from Speedway. I figure if he could pull that off he can sure guide me through my Mustang II IFS installation. I should have snapped a few pics while we were there, but I will for sure next time. Hopefully we will be making some progress this weekend!
greatguy57078
greatguy57078
I am wondering if there is such a thing as a way to set up for a 4 link and coils for the rear, so a person could go in the direction at a later time. Or is there a cheaper setup that anyone knows of? Maybe IronbenderII would throw me a discount for some advertising! I know...wishful thinking!;)
behemoth
I have briefly spoken with Jack Ironbender about his setup. I think most all of it would work for the lowering. the center section would not but that would have to be different anyway as we need to keep the top of the diff clear.
I am going to take some pictures to the air bag guy ( barnes fabrication ) and see what he thinks.
greatguy57078
greatguy57078
Sounds good. Please keep me in the loop on this issue. Thanks for sharing!
greatguy57078
greatguy57078
* I spoke to Van again today, and the motor mounts are on their way to South Dakota, with custom made headers soon to follow! (Thanks Van of Tumblin Auto!). It looks like there is no turning back now. This machine will be powered by the 4.6 DOHC Mark VIII engine. Hopefully we will be getting some work done this week/weekend. We are going to get together after work tomorrow and lay out what needs to be done, and will hit her hard Saturday afternoon if our schedules work out. I will take pics and post them ASAP.
behemoth
Sounds good, I would like to get back to work on mine, but the bill paying job and Christmas are going to keep it in the garage for a while.
April is coming fast and it is not looking good.
greatguy57078
greatguy57078
Slow but steady. We are making progress. I hope to put in a few hours on it tomorrow. We cut all the items off the frame that were no longer needed, such as the radius arm mounts, motor mounts, shock and spring towers. And that POS tow bar thing is going tomorrow too!
I measured and marked up the Heidt's crossmember and took it to work this morning to cut into it with the plasma cutter. I went the extra mile and set it up in the CNC mill and trued it up. I was surprised how close Dennis (hot rod guru!) was able to get using the plasma cutter. It was well within .030 on every line. It will sit exactly (+ or - .005) 3 1/2" from the center of the lower control arm bolt center line.
We left just enough in the center to grind it and get a tight fit between the frame rails, as Heidt's suggested. "It is easier to remove material than it is to add it back on".
I am pretty excited about getting this set it tomorrow. It almost looks too easy, and I am sure we will have a few obsticles to overcome before it it welded in completely. As always, I will update with pics when I get back home tomorrow night. Stay tuned...
Broncoholic1
94 Thunderbire IRS
I have a build in mind for a 94 Thunderbird IRS, and a 2001 Lincoln IFS for a low street machine. Keep up the good work I might go Must II?
greatguy57078
greatguy57078
That motor in the background looks like fun ;D
Good to see some progress!
Actually there are two of those motors sitting side by side. He is putting the other one in his 65 Mustang fastback. :cool:
greatguy57078
greatguy57078
There just so happens to be a guy that sells a swap kit for the TBird/Lincoln IRS. I plan on banging some gears so I stuck with the 8.8 Explorer rear axle. Here is his website link for anyone interested. Please let him know you heard about it from me.
http://team321.com/truckirs/HomePage.html
greatguy57078
greatguy57078
Another short day, but we are getting some work done. I did have to recut the crossmember a little more before we were able to get the rake that I am shooting for.
I had cut the notch for the crossmember originally down 3 1/2" but went another 1/4" (pic 008) in the front to allow for around a 3" rake front to back. I left it a little long in the center to allow for a nice tight fit between the rails. (after very little grinding I might add). This dimension was right around 23 5/8" before the final fit. It went rather well (after very little grinding I might add), and is almost perfect level right where I wanted it (pic 014).
I will be working on the spring towers tomorrow. I will be cutting the notches and trimming them in to specified locations. We will be back in the shop early Saturday morning, so I hope to get alot of work done, including the notch kit for the rear axle installed.
greatguy57078
greatguy57078
Here is the other project my friend Dennis is working on. I cannot say enough how much I appreciate him taking time out to help me with my work. Thanks again Dennis!
greatguy57078
greatguy57078
I took the spring towers into work today, and marked them up and cut them out. I scribed a line 1.5" down (pic1) on the front notch, and 1" down (pic 2) from the top on the back notch. I cut 2.8" into the sides determined by the frame width. This leaves just enough material to make the necessary adjustments for the proper fit. We blew them out with the plasma cutter, and I deburred them (pic3).
It looks now like the weather might hold out for tomorrow. We are planning a long day and hope to have the Mustang II IFS mounted and move on to the rear frame notch. If it works out maybe we will sling the 8.8 Explorer rear axle
greatguy57078
greatguy57078
I also used these schematics that eb66to77 sent me to help me do the math to determine dimensions. Just thought it might help someone else out in the future. Thank you eb66to77!
