LOWERING my Bronco
greatguy57078
greatguy57078
Well my alarm went off at 3:45, and I have not been ale to get back to sleep. I guess that shows you how pumped up I am to work on this project! I did some surfing while I was laying in bed (yes I have a 19" flat panel that cantilevers out from the wall!) and came up with some useful websites for the project. The pic shows a Cobra motor, but I figure it should be a good reference point (I will refer back to it later).
I am on my way to watch my daughter do her indoor track thing, and then its off to Bronco hot rod heaven! News at 6... (or whenever I get back home!)
behemoth
Nick if you are around and want to sand and smell some nasty fumes come on by. At this time the underside of the frame is drying. I am now looking at the floors while it is drying out.
SC74
Looking forward to seeing what you got done today GreatGuy. Very interesting project - you've got some great thought and work into it.
greatguy57078
greatguy57078
We mounted the headers and trans. It was obvious right away that the passenger's side header would not clear the frame. I am sure the mod motor guys are more that aware of this issue. At least we were able to get a look at the trans to the frame. Pics coming...
greatguy57078
greatguy57078
The driver's side looks perfect, with about 1/4" of clearance between the header and the frame. The passenger's side is a different animal. The header is made to angle out around the starter, so it hits the frame. This is going to be a problem, unless the header can be modified or custom made like the headers that Van Tumblin makes/sells. I will have to make a few more calls to see what the options are. At least we were able to get a few measurements for the transmission crossmember today...
behemoth
The narrow bronco frame sure causes a whole lot of issues. From the pictures that mod motor looks like it is sitting really low in the frame.
Looks really good sitting in there.
I am planning on using the stock mustang crossmember, only trimming it to fit in or below the bronco frame rails.
That drivers side header looks good as well but how or where will the steering shaft go?
greatguy57078
greatguy57078
It looks like these will work. I was so busy dealing with the passenger's side dilema, I never even thought about the steering shaft on the other side. Thanks for reminding me Bill. Maybe with these Blue Oval Industries headers I will find the solution to both problems?
behemoth
its hard to tell from the pictures, but it looks to me like you would just be trading the passenger side clearance issue for the drivers side.
greatguy57078
greatguy57078
That might be. I have emailed Van Tumblin to have him send a few pics/specs/thoughts about his custom headers. The stock manifolds look like they would work, but I would really much rather have some headers. I will at least be able to resolve this issue for anyone else moving in the same direction.
Here are a few other possible part options, although something in steel would be better if there is to be any cutting/modifying.
73stallion
Eugene, OR
nice coupe! even nicer to see someone using a ford in a ford.
was thinking about something last night. since these are gonna be 2wd lowered broncos, has anybody thought about what one would look like as a panel? wouldn't be hard to fill in where the side windows are in the roof and upholster the insides.
greatguy57078
greatguy57078
I have thought about that and a hundred other ideas. I wish that I worked a a custom rod shop! He fired up that 460 yesteday with open headers when I walked in the shop. My ears still hurt and I am not kidding. I could not get my hands over my ears fast enough!
behemoth
Mine is going to be at least full time convertible or running the hard top. So a panel is not that far off, the loss of visibility though would really suck.
The problem with most of the aftermarket headers is that most of them are built to fit the stock exhaust or a specific manufacturers exhaust. So the collectors are going to be in the same locations. Other options from other vehicles with that engine though may work. Possibly one from each ?
greatguy57078
greatguy57078
The stock exhaust would work, but you would have to cut the end off and turn it down instead of out towards the rail. That is why I think you would want steel as it would be the easiest to customize for me anyways. Unless there are some that would prefer cutting and welding cast iron?
behemoth
that fit looks really good, and if the drivers side is the same then only a dimple in it may be required. You could always run them over and on the outside of the frame. This way you have more room for the transmission and other things?
bluebroncodrive
I had the same problem when dropped the 460 in my Bronco rod the pass side ended on the frame I was unable for find any stock or after market manifolds or headers to fit, I just ended cutting the end off and tack weld it in the place i needed and putting the manifold in the BBQ for an hour to get it very hot and then welding it. After some grinding and then sand blasting you can't even tell what I did
greatguy57078
greatguy57078
I found this schematic on the internet. I thought it would make a good visual aid to demonstrate what we are up against when you take on this monster motor! RED is the 351W...GREEN is the FE (BB) engine...and BLACK shows how big the 4.6L DOHC engine is. Pretty good visual aid huh?
greatguy57078
greatguy57078
I called Sanderson's out in Cali, as they offer custon made headers on their website. I have emailed pics and their expert guy is supposed to be getting back to me in the morning. In the meanwhile, I have it through another source that the Ford Racing headers might work with a little persuasion. It would need to be trimmed off, rotated and possibly extended back. Pic attached...
