LOWERING my Bronco
greatguy57078
greatguy57078
I had the same problem when dropped the 460 in my Bronco rod the pass side ended on the frame I was unable for find any stock or after market manifolds or headers to fit, I just ended cutting the end off and tack weld it in the place i needed and putting the manifold in the BBQ for an hour to get it very hot and then welding it. After some grinding and then sand blasting you can't even tell what I did
Here are a few pics the bluebroncodrive sent to share. He is using a 460 with the same passenger's side header problem. I personally love the 4 link and the air bag setup. This is exactly what behemoth has been talking about (including having to cut into the bed!)Thanks for sharing your pics Edgar!
bluebroncodrive
Thanks great guy for posting the pics, I have not air bagged the front yet and the cross braces on the rear are temp until I locate the fuel tank in it's place I hope to fire it up for the first time in a few weeks
behemoth
Very nice, makes me like the wagon look even more. That thing will be a monster, the 460, the short wheelbase and light weight, I think wheelie bars might be needed.
I like the look of the rear all tucked up in there, but the bed cuts are too much for me right now. Got any pics of the rear suspension you would like to share ?
greatguy57078
greatguy57078
Here are a few more pics that Edgar sent me. I have posted just the ones that show his rear suspension. I have one question...is it possible to hijack your own thread?:-X LOL!
greatguy57078
greatguy57078
I stayed after work today and finished fabbing my motor mounts. I ended up trimming the driver's side down, and adding material onto the shorter passenger's side. I think that they turned out pretty nice. I will post pics tomorrow after I get them welded up and clean them up. I feel good. At least I got something done while I am waiting to resolve the header issue. I missed the custom header guy by 3 minutes today, so I have to call back again tomorrow. Oh well...%)
behemoth
Thanks for the pics of the rear suspension. Yet another route to look at.
I have been messing around with por 15 on the frame and it looks pretty bad. I tried the semi gloss and it is streaked with gloss and just does not look like I had wanted. So we will be stripping, cleaning and painting that again.
greatguy57078
greatguy57078
That sucks Bill. I have heard that stuff is a real PITA to remove once it is set up. You're going to have to update us on how that goes. I hope that I can find someone to spray it on for me when I get to that point. I am leaning towards the POR15 and then the Chassis Silver. Well...back to work.%)
Heus33
Awesome! That wagon is screaming for a chop! :eek:
broncomitch
west jordan, utah
The stock exhaust would work, but you would have to cut the end off and turn it down instead of out towards the rail. That is why I think you would want steel as it would be the easiest to customize for me anyways. Unless there are some that would prefer cutting and welding cast iron?
had about the same problem in my buddys flatty. it was shooting striate back toward the fire wall.. he took the manifold to the local engine shop (troy's custom engines in rigby idaho) and he chopped it off and angled it down and welded the end and the gap with the cash iron welder thingy he has. turned out WAY good it was beautiful and strong.. i droped it and didnt brake ;D
greatguy57078
greatguy57078
We are thinking we are going to modify a set of the Ford racing headers. If we can make the passenger side look similiar to the drivers side, it should create enough clearance by pretty much going back instead of down. It should also resolve the problem of running the Mustang II power rack steering linkage on the drivers side.
greatguy57078
greatguy57078
I welded up the motor mounts today, and cleaned up the welds. I figured we would weld them all the way after we make sure that they won't need to be modified again in anyway. They should be plenty sturdy as they will be welded back on the inner frame as they were stock, but with the custom braces welded on top of the Mustang II cross member. Good looking and functional!
broncomitch
west jordan, utah
goin to be lots of work. but i dont see why it wouldn't work. do they make a long tude header of it you can just shorten up? motor mounts look good btw
greatguy57078
greatguy57078
There is a Pacesetter long tube header that I liked. I will have to go back and find a part number.
greatguy57078
greatguy57078
Well I had an OK day. Looky what I found, and it was only 120 miles away.%) A 1977 Lincoln Versailles with a disc brake 9" rear end (31 spline and POSI!).:eek: When we backed up to pull it on the trailer, I found a 79 F150 custom parked right behind it with a tilt column and a NP205! ;D Thank you Lord!;D
broncomitch
west jordan, utah
can you say...BIG PIMPIN!! hahaha i got the same disk brake set up from the same car sitting in a bucket i hope one day to use. but looking slim.
ya know the more progress you two make the more i want to build one too :(
i was thinking tho i have a mustangII thats not going to go anywhere (drag car project) think its possible to cut the front frame off and weld it and brace it and sleeve it to the front of a bronco frame?
i know chevy guys LOVE to do that to there muscle cars and street trucks.
greatguy57078
greatguy57078
:cool:
Not only can it be done, it has been done (see post #281 ). I think I have more pics of the stock Mustang II setup on a Bronco somewhere...but seriously, let me know if you want to get rid of that Versailles setup...;D
greatguy57078
greatguy57078
Daytime pics... not bad at all. A little paint here and there and it will be a great looking machine. I am going to pull the 9" for this street rod and swap the 8.8 Explorer back under the Versailles. I guess I should have snapped a couple of pics from under the rear. It is so clean underneath that is is actually SHINEY!:cool: Surface rust only on the drive train.
This qualifies as a donor vehicle, so I am not hijacking my own thread (again)....am I? %) Anyways, back to the chopped and raked halfcab street rod. :cool:
greatguy57078
greatguy57078
My 15 year old boy thinks it's awesome, so that's all that counts for now. In a couple years it will magically transform into a Mustang:eek: ...or maybe a Bronco!:eek:
behemoth
Just curious as to the change in rears? something I should be looking out for ?
