LOWERING my Bronco
greatguy57078
greatguy57078
I am searching for a 4 link (bar) kit. The popular opinion is that with the narrow frame rails I need a parallel bar kit. I would appreciate it if anyone has ideas or suggestions where to buy from. I hope to have one purchased and on the way to me by the end of this week. I will concentrate on the trans crossmember and pulling the Versailles 9 inch this weekend, so I should be ready for the 4 link by the time it arrives...
greatguy57078
greatguy57078
I found the 4 link I was looking for. It is a beefy 1 1/2" bar parallel kit from Suicidedoors.com, made by Thorbecke Brothers.
Contact Ricky!
rickyf@suicidedoors.com (812)-782-3581 ext 223 He will take care of you! Tell him Marty sent you!
http://www.suicidedoors.com/4-link-kits/thorbecke-brothers/parallel-4-link-kit
Lead time to build the custom kit is around 2-2 1/2 weeks. Meanwhile... the crossmember should arrive and be installed by this weekend. Progress is progress...
greatguy57078
greatguy57078
;D Fedex dropped off the crossmember today. We should have it fabbed in tomorrow. I will take a measurement for the driveshaft and be ready for the 4 link install that is coming soon. I can't wait for the warmer weather. It was 1 degree when I went to work this morning, and warmed up to a VERY toasty 14!:cool:
greatguy57078
greatguy57078
We bolted up the crossmember to the trans, and measured the gap between that and the frame rail. After considering how to fill the gap, we decided to put the OEM trans support brackets to use. We filled the openings with two 5" x 6" pieces of 1/4" flat steel.
We also measured up for the header mods. It turned out that we did not have the 2.5" stainless tubing we need, so will have to pick up a 2 foot piece this week after work. It isn't the easiest thing to do...cutting up a brand new $400+ set of headers, but if it was easy we wouldn't be doing it!
On a side note...in our seach for a piece of stainless, we went over to Dennis' brothers place. I got to meet his brother, and take a look at his '40 Willys street rod with a 500+ hp BB 460....and it is SWEEET! I will have to take pics next time...
behemoth
Crossmember looks really good.
I am going to modify a stock mustang crossmember for the aod on mine.
Here is the finished steering shaft mod and the final angle. I can cycle it side to side with no bind in the u joints.
Paint problems again on the engine compartment no problem though I am not really done cutting up the inner fenders yet anyway.
greatguy57078
greatguy57078
Well the custom headers are coming along. With a couple of 2 1/2" diameter stainless steel extentions ( 3' piece for only $10!), there should be no problem running the rest of the exhaust back from there. I have to admit the driver's side looks nicer than the passenger's side to me. Stuffing that fat 4.6 DOHC doesn't leave alot of room!
greatguy57078
greatguy57078
After some discussion today, it looks like the passenger's side should have some type of an "S" bend possibly. At least it looks like it might have a problem clearing the firewall. It might just be very close but still something to look at and pull a tape on. It's always something....
greatguy57078
greatguy57078
A peek into the future. We are waiting on the 4 link, so we installed the halfcab that will (someday) be chopped and raked, then drove into town to the body shop (which was fun with my son!) to see what their schedule looked like. The hole in the roof will eventually be filled in with a ribbed section, possibly out of a Pontiac Aztec. I still want to be able to remove the top/window frames to run with just a windshield. It sure was great to have weather nice enough to work out in the driveway for a change.
greatguy57078
greatguy57078
LOL! That's my boy. You have no idea how many times a day I tell him that!
broncomitch
west jordan, utah
im sure as many as i hear it;D sadly tho....i have no butt.
i have the symptom called '' HANK HILL BUTT'' so needless to say my pants have nothing to hold them up. a belt helps, but they still fall down. :cry:
to all i have made blind im sincerely sorry lol
greatguy57078
greatguy57078
Changed the passenger's side a little. It was shortened and welded the flange at a slightly different angle. It looks like this will work out better for bolting up the rest of the exhaust and staying back away from the firewall. Note the blue reference marks on the top of the frame rail. This is the imaginary line marking the flat of the firewall. I posted the old and the new pic showing both sides of the headers to show the change.
The 4 link should be here next week. Moving along slow I know, but moving just the same.
behemoth
The headers look good. Getting closer every day.
Here is the snag I ran into today, do you have any pics of what Dale may have done with the front inner fenders.
These pics are taken not even close to ride height. The tire will get closer when the engine and transmission are in.
Looks like I am going to be cutting the inner fenders out.
Two steps forward and five back.
greatguy57078
greatguy57078
Dale has never mentioned anything with the inner fenders. I will shoot him an email along with your pics, and pass the info on to you. It's alot of work... doing what we are doing...but I smile every time I drive home from the shop thinking about the day when this machine fires up and drives. I hope to get some work done this week, if the 4 link shows up.
bronko69er
EB Addict
Renton, WA
This build has inspired me to do the same thing on my next bronco (don't know how soon that will be). [Mini-hijack]
Some of my goals (some similar to this) would be:
uncut tub
Mustang II front end
Explorer rear with discs and tru trac
F/R sway bars
air bag suspension
front and rear roll pans
shaved door handles
lowered floor boards/ tunnel work and low profile seats
chop windshield and door frames as low as comfortable
LS6 with a 6 speed manual :-X
motorized soft top
hard tonneau like bed cover
brushed aluminium behind seat roll hoops
metalic silver paint
vintage air
power windows
20" wheels
tubbed rear if necessary
filled in tail gate with plate recess
exhaust rings for exits out of lower rear corners......
[/mini-hijack]
behemoth
We all appear to think alike
uncut tub *
Mustang II front end *
Explorer rear with discs and tru trac *
F/R sway bars *
air bag suspension *
shaved door handles*
lowered floor boards/ tunnel work and low profile seats *afterthought now
chop windshield and door frames as low as comfortable. * even with dropping the floor the 3 " seems about right to me.
LS6 with a 6 speed manual * why not there is nothing bronco left but the body.
motorized soft top * I am keeping the hard top and going for a rag top center. Only because the PO installed a camper vent.
hard tonneau like bed cover *
brushed aluminium behind seat roll hoops * Cobra style for me.
metalic silver paint * white.
vintage air * later
power windows * window frames coming off.
20" wheels
I am thinking that the exhaust will come out just in front of the passenger tire hidden in the fenderwell. there is not a lot of room under the rear with the 4 link and air bags for exhaust.
In the end it is a project that is probably never going to be done, many tweaks and changes as different ideas come up.
