LOWERING my Bronco
greatguy57078
greatguy57078
I need to cut out the notch for the steering shaft and some other things.
What do you need to notch? Man I wish us Bronco street rod guys were closer together. It would be cool to be able to physically help each other out. Share the knowledge Brother!:cool:
greatguy57078
greatguy57078
I like these engine mounts they appear to have a whole lot of options built in them. Just a little cut and grind to get them where you wish.
That is why I went with the motor mount change. *Anyone doing the 4.6 swap that is looking for bolt in motor mounts I have a great set fo sale.*
The motor should slide right in tomorrow and then me can move on to the next item. I was going to weld side gussets on them today at work, but after looking them over I seen that the tabs were set into milled slots and welded in VERY solid on all the tabs. No gussets necessary.
Next...on to the trans mount and then I will have to decide to go with the leaf springs or do the 4 link.
behemoth
I am using the stock engine mounts and the steering shaft comes right up through the back side of the mount. I will just notch the mount a little to get the steering shaft through it.
Just painting things as I go along lots of little things needed some work, the dash is next as well as the bulkhead.
greatguy57078
greatguy57078
Cool! I was worried about having the same problem, so that's why I bought the other mounts. Remember the old saying on here..."pics or your lyin'!"
555dog
Hey Greatguy57078, sorry for going off-topic, but i've got a question for you. You posted about seeing a late 70s four door bronco in this thread:
http://classicbroncos.com/forums/showthread.php?t=117914&highlight=centurion
It's driving us crazy at fourdoorbronco.com that we can't figure out where it is. I know it was close to a year ago, but do you remember where you saw this four door bronco?
Do you have any idea where the 79 four door bronco that you saw is? They're pretty hard to come by.
greatguy57078
greatguy57078
;D That looks to be a pretty easy fix Bill. I don't think you will have any problems, as it doesn't look like you will have to remove much material. I think I would just trim the bottom off like in the pic (yellow line). If you wanted you could always weld in a small piece of flat if you felt you needed the support back there.
Feel free to PM or email if you have questions. That way I will feel less guilty about bothering you with my questions!;D
greatguy57078
greatguy57078
We got the motor mounts welded in today also. They worked great and took very little time to set up. The passenger's side mount ended up almost dead center of the Heidt's crossmember. We set it as far back as we could with just enough room to work on the A/C if that ever needs attention. Just to let you guys know, the A/C and the PS accessories run on the bottom under the cylinder heads (in case that got you wondering). I forgot the camera today, but I will post pics ASAP.
Now I have to measure up for the trans support mount. That looks like it will be another easy thing to do. I am going to flip the OEM Bronco trans mount support brackets, and just build off of them. I am trying to decide what 4 link to buy. Any suggestions?
behemoth
Well not a whole lot done on it today.
I looked at the steering shaft and hit a snag, stepped back had a beverage and found a solution.
The angle from the steering box input to the end of the column is to steep for the flaming river u joints. It would bind badly. So the solution is to cut the end of the column off and weld it back on removing a few inches of column that I do not need. This will give me more angle to work with on the steering shaft and u joints. There are two marks on the column in the picture, the upper one is where the column would end, the lower mark is the amount of column end I need to keep for the bearing.
I figured that I would just weld in a chunk of tubing to give the mount its strength back.
The inner fenders are coming out as well, I do not know how much of them I will end up with if any. Just need a little more tire clearance on compression.
Also it looks as though I will also need some wheel spacers for the front. The rims and tires are set to far inside with the 56" wheel base crossmember.
This will also help with the rims hitting the a arms.
The other pic is well just where it will sit for some time now. Had to drive the other one today as I needed to make the tires round again.
greatguy57078
greatguy57078
Measuring 1 5/8" back from the center of the mounting holes, we trimmed the tabs off (pic below). They pretty much butted right in up against the Heidt's Mustang II crossmember. We leveled the engine across the front and centered the trans between the frame rails. The tabs were then ready to tack in.
Looking good Bill. I can use the pic of your steering assembly. That is one item that will require some thought, as most of the room on that side is header space. Getting it under and through is not the problem. Manuevering upwards to meet the column without binding up will be the challenge. Your pic serves as a great visual aid for that dilema.
behemoth
With the column shortened this is a better angle for the steering shaft.
greatguy57078
greatguy57078
That looks really good to me. I wish I would have remembered my camera yesterday so I would have a view of what my angle would be. All I can say is I am VERY pleased with the look and fit that we have. It sits low in the frame. We have about 1" to 1 1/2" from the back of the driver's side head (farthest point of the rear of the 4.6 DOHC engine) and the firewall location, and about 1/4" between th A/C accessory and the Mustang II crossmember. We went as far back as we could and still access the AC unit fully.
On another note... with the smaller size of the Hitachi starter, it wasn't even necessary to clock the starter. It fit right in with plenty of room between it and the inside of the frame rail.
greatguy57078
greatguy57078
How hard is it to shorten the column? What does that involve? I have a '79 Bronco MANUAL tilt column that I am going to convert to. I believe that they are equal length to the stock Bronco column?...right?
bluebroncodrive
I rotated my rack to get a better angle for the steering shaft also I found that the early F150 steering non tilt and looks just like the bronco one had the same wiring as my bronco and is about 3 inches shorter I will have to remove the column mounting braket and reinstall it on the F150 column. I was told not to get the steering shaft u-joint more than 30 degs or it we be a problem.
behemoth
Shortening the column was easy, the first cut was 3/4 up from the end. The second was about 3" up from there. Then it was welded back together, I am not using the column shifter so It was a simple option. Now I have to put the column and wheel together to get the correct length for the steering shaft. Then cut the engine mount for u joint clearance.
greatguy57078
greatguy57078
The way I see it, I may try to lower the column before I try to cut it. With it being a tilt column, I figure I can lower it and adjust to get a better angle. I will take some pics when I get back over to the shop later this week.
behemoth
lowering the front part will work as well, the firewall will need mods to fill the gaps.
Since you are using a floor shifter you could just shorten the column and get the same resulting angle.
This is the completed chop of the column.
The next is to chop up the steering shaft and see what it looks and feels like while turning.
I looked at the flaming river u joints and with some careful grinding you can gain a few more degrees out of them.
greatguy57078
greatguy57078
Will a new bearing press in the end of the shortened tube? What about the splined end of the shaft itself? I am going to have to dig out my column and take a few pics tomorrow.
behemoth
At this point the actual steering shaft is the one from the manual box. So I am looking at getting one 3/4Round to 3/4 round flaming river joint for the top and one 3/4 round to 3/4 36 spline for the box end.
I am going to cut the stock manual steering shaft down no splines on this one.
greatguy57078
greatguy57078
I trimmed off the end of the OEM passenger's side exhaust manifiold today. I cut it off between the last and second to last ports, and then trimmed off the last port itself. This will give us the maximum amount of material to form and weld back on to the Ford Racing header. The idea will be to get the end pointed back and down inside the frame rail.
Onward and upward...
