LOWERING my Bronco
greatguy57078
greatguy57078
I am pumped! Hopefully by tomorrow afternoon I will be ready to at least be able to bolt up some wheels and tires and roll the frame back home soon. I can't wait to have the frame painted and have the Mustang wheels mounted with some fat rubber underneath.
behemoth
If you got the same front springs as I dont waste your time with them at this point they are about 3" to tall and way to stiff. with the weight of the engine it only dropped a bout 1/4" . A lighter weight spring is all that is needed.
greatguy57078
greatguy57078
I shot Dale an email about your spring dilema. I know the guy at Heidt's told me that ater a few (500?) miles the springs will set differently. I hope to hear back from Dale soon. I will be sure to pass the info on. Off to the shop!
greatguy57078
greatguy57078
It didn't go too bad, although I did not get as much done as I had wanted to. It is my first 4 link, and I thought it would be easier than it turned out to be. I spend most of the time grinding off and cleaning up what was left after cutting off the leaf spring brackets. After setting it up and looking it over, I have decided to go with a different axle mount, so it will allow me to mount the shocks outside frame rails. There is no room for another bracket, so it has to be part of the bar mount. I found a place online that does some awesome custom welding. They have demo welding videos on youtube.com that explain how to assemble some of the items they sell. You can either have them weld it up, or weld it yourself. ( welderseries.com ) They made alot of parts for the do-it-yourself guy that would like to mix an match components.
greatguy57078
greatguy57078
The nine inch cleaned up very nicely with a light sandblast. I will have to wait for the new custom brackets before tacking it together. There is 5 inches between the axle and the frame in the pic. The axle is at ride height, but there will be less than 5 inches when it is all done. So the bars will end up more parrallel with the frame.
behemoth
looking good, on the 4 link. Barnes Fabrication is doing a 4 link for mine with a wishbone rear. I messed around briefly with the front springs and with the arms parallel to the ground they will not work. The coil measurement and the height measurement do not work out for any kind of ride that I am after.
The 1" wheel spacers are off again, possibly will run 1/2 to clear the a arms. The wheels tucked in at the height I am at shooting for it looks a little better to me.
I would recommend that you look at the inner fenders and look to raise them or remove them all together. At the ride height we are at we will hit them with a bump.
No pics at this time, forgot the camera.
greatguy57078
greatguy57078
Thanks for the update behemoth. It gets frustrating at times, but man it feels good when you sail passed the problem! Stay motivated!;D
greatguy57078
greatguy57078
I drew up some custom brackets and am having a local fabrication shop cut them out with a CNC plasma cutter. They should be ready tomorrow. I will explain what I did and why I did it when I have them and can take pics. I am hoping this is the last modification before I buy shocks and tires and roll this beast out in the sun. Update tomorrow!
greatguy57078
greatguy57078
Ok. We got some work done today. I had the custom axle mounts with shock mounts added to the bottom rear. I chose to do this to be able to run the shocks to the outside of the frame rails, instead of having to tip them inward. Pretty close to the stock location and angle, but with ALOT less clearance.
I had to have 2 made with a 3" radius, and 2 with a 3.25" radius where it welds to the axle, due to the Versaille rear end tapering. It actualy goes from 3"-3.25"-3.5" moving inward toward the pinion.
greatguy57078
greatguy57078
We squared up the front and rear brackets, making sure that they were straight up and down and parallel with each other. At the same time we stuck a magnetic level on the front of the pinion to be sure that it was straght up and down as well. We centered the axle and re-verified the other dimesions. The axle brackets were then welded into place.
After the rear brackets were tack welded, it was time to set the fronts into place. Checking again to make sure they were still straight up and down, I pulled a tape and positioned the rear axle to bring it to the stock 92" wheel base. After checking to be sure they were running straight along side the frame rails, these were tacked on also. It is really looking straight and strong now!
greatguy57078
greatguy57078
Next came the panhard bar. This thing is 1.25" thick! When I took it out of the box I thought it was one of the larger parallel bars. It would no way fit parallel across the rear axle, so we had to tip the mount forward. It fits in snug with about 1/8" clearance when you cycle the axle and bring it axle to frame.
greatguy57078
greatguy57078
It looks like around a 13" shock is going to have to do. When you push everything down, what you see is what you get. There is VERY little or no room for options. I have some finish welding to do, as well as clean up on the frame. Holes like where the stock steering box I want welded in. This is no show truck, but I want the frame as smooth and clean as I can get it. I hope to have her rolling in the next 1-2 weeks. Feel free to cheer me on!
Smokeater11
Auburndale,FL
greatguy I have been watching this thread for some time now and I have only one thing to say.....you are one HELL of a fabricator!!! Where you come up with half of this stuff I'll never know but somehow, someway, you are making it work. I for one am very impressed with your ingenuity and skills. Keep up the phenomonal work man, you really are doing a great job!!
greatguy57078
greatguy57078
Hey Bill...FYI - asked Dale about the springs that came with his Heidt's kit, and here is his reply:
"My springs are too stiff as well. I currently have them pulled together with 1/2" threaded rod. I was told that Pinto springs work perfectly but I haven't been able to locate any. The only other choice and last resort is to cut one coil off the top. I'd rather not do that if I can help it."
We did all the finish welding and grinding tonight. I will slide the engine/trans/rear axle back in next. I should have my front suspension together by the weekend. I will post any info ASAP. Time for YOUR update now...Bill?...Edgar?....anyone else?
behemoth
If you can mic your coils and give me that measurement we can see what we all have. I figure JPL has 3 coils light, med and firm. We all ended up with the firm you know truck and v8 so it is my guess we got the 365lb springs.
If you cut one coil out the spring rate will go up making it more stiff, I was ready to cut them as well. .
Heights sells the coils for $99 a set, I will go to the junk yard and see what I can find.
The coils I just pulled out of my focus are close, but no luck.
I may just bag the front and forget about the springs.
Muddn7
alamogordo, nm
not much on lowering, but.....
I feel weird writing this, but heres an idea.... I was just looking at shocks to eliminate my coils in the front. I decided it was too much of a project at the time (financially). I did go to a custom fab shop that fixes, and sells parts for lifting, and probably lowering an off road vehicle and others. He had several options with air pressure to set ride height, which is what I was looking at. I have 3.5 inch suspension with 2 inch body now. I was thinking of getting these shocks to add my lift by a couple of inches, but only for offroad. They make them with air charge, and can be purchased reasonably. So I would suggest going to a custom fab shop and seeing what options you have on pneudraulic shocks....... Maybe even build an onboard aircompressor under the hood to inflate after shows..... The shocks I looked at eliminated the coils all together. As for the rear: You can put a swap on your swivel mount for your rear leaf to the front with solid rear. Then you can axle over. Just an idea. If you use either, send me some pics, I wouldn't mind seeing how it works for ya.....
greatguy57078
greatguy57078
I was thinking of maybe going with coilovers, but I already have alot invested in the IFS. I have changed direction so many times, I don't want to end up getting lost!%)
behemoth
I was thinking of ordering the light springs, and seeing where I ended up. If they were to tall cutting a coil from them would not be as bad as cutting one from the firm set. the front sway bar is also unuseable. at least the one I have.
headed to the junk heap this weekend in search of pintos and mustang II coils.
measure one of the coils and let me know what it is, I am just curious as to if we all got the same coils.
greatguy57078
greatguy57078
I will take a measurement tonight, and get back to you. I am trying to come up with the $400+ for the REAR coilover shocks I want/need right now!:eek:
