LOWERING my Bronco
greatguy57078
greatguy57078
Holy Cow! You have been busy! That 4 link looks plenty sturdy, and your motor looks great too. I still think about how much less work it would be to go with the 5.0, but I am tired of changing my mind so I am sticking with the 4.6 DOHC.
We finished the welds on the frame and stripped it back down. Now I have to load everything up and bring it home. I will then have the frame blasted again, and get ready to paint it. The shocks came in yesterday, and look great. I am debating whether to keep the bearings that they have mounted in the top, or knock them out and go with the bushings. The bearing is only 1/2", and the bushings would be 5/8". Anyone have any thoughts on this?
Heus33
What coilovers did you get? Get some pics up! Any progress on your front facia? I shelved mine for the time being - can't convince myself to start fabricating just yet.
greatguy57078
greatguy57078
I went with Aldan coilovers for the rear. I will have to look but I am thinking they were the 16.5" 658 model. They should squish down to at least 15" at ride height (30 degrees back), leaving me with 3.5"-4.0" clearance between the axle and the frame notch. I have to get my halfcab out of my garage and bring home the frame in the next day or so. I will post a few pics then. Stay tuned...
greatguy57078
greatguy57078
After looking at your pic, I wonder how much room I will have under that wheel well for wider tires... with the coilovers?
behemoth
The rear end clearances for both the outer and inner fenders is tight. I will try and get a picture later on today.
For the front I am going to go with the QE1 coil overs at some point.
The pic is with the bags empty sitting on the bump stops. The problem I have with that is I really like that height. So the bed floors days are numbered as well as a much larger c notch.
greatguy57078
greatguy57078
Two questions Bill:
1 - Do you sill have the 235's on the back rims?
2 - Is your ride height in this pic "with the bags empty and sitting on the bump stops"?...or about the same?
behemoth
That pic is before bags stock flat leafs. Stock tires I have changed nothing tire wise.
With the bags I sit lower than in this picture. Its raining here in sunny so cal so I can not get a pic of it with bags empty.
greatguy57078
greatguy57078
I am hoping that mine ends up looking close to your pic in the driveway. Me and my son went over and cleaned out the shop I have been working at all winter. All that is left over there now is the crate 4.6 DOHC. We dropped off the frame at the blaster again, and it will be ready to come home with me tomorrow. Then it's POR-15 time baby!;D Perfect timing...the halfcab goes in for the chop tomorrow, so I have a spot to do the finish work on the frame now. Pics will be posted!:cool:
greatguy57078
greatguy57078
;D
I just wanted to tell you Bill how impressed I am with your 4 link. That is very similiar to the setup I was looking into before I bought mine. Out of the 4-5 manufacturers I talked to about their setups, none of them had pictures of the system installed. Yours looks very compact and functonal. I like it!;D
behemoth
There was just not enough room to go with the standard triangled 4 link, and this wishbone setup solved that. The three link like you have done was another option, but I wanted to push the rear axle back and there was concern with the panhard bar movement being so short. I looked at a kit like yours long and hard and was about ready to go that route.
The wishbone 3 link had its issues as well, mounting it high enough to clear the drive shaft with the axle at bumpstops was another trade off to resolve. There is less than one degree of pinion angle change/deflection during full cycling. Which is a good thing.
I wish I could say that I built this part of it but I did not. This is a Barnes Fabrication creation. It was not something I felt comfortable attempting at this time.
I think the wheel base is now close to 94" between the front and rear changes.
There are some tweaks to it coming in the future, when the bed gets modified/raised to clear the new c notch height. At that point we will be changing the rear shock mounts as well.
Thanks, it is always enjoyable to see the different directions taken to get basically the same thing.
More pics in the next few days.
greatguy57078
greatguy57078
We got the frame back home from the blaster. I really like how the welds smoothed out. Just a little more clean up polishing up some of the welds, and it will be ready for the POR15. I am leaning towards the Stirling Silver chassis finish.
behemoth
very pretty stuff there, I wish I had taken the time to have mine blasted.
greatguy57078
greatguy57078
I have a urethane body mount kit, but I don't think it has all the hardware. Where do you get the rest of the metal parts from if you need them?
Heus33
Two questions Bill:
That is too freaking cool - everyone should have this combo in their driveway. :eek:
bronko69er
EB Addict
Renton, WA
Hey Greatguy, can you get more detailed info from Dale on how he eliminated the vent widow and what is involved fab wise? I really want to do that on mine.
greatguy57078
greatguy57078
I will email him and see what he has to say. I will be doing the same with my vents shortly. The guy with the 30 something Dodge is still parked in my spot at the body shop, until Tuesday next week now.?:?
The good news is that I have a little sanding left to do, and then it's on to the POR15. It should be all black by tomorrow afternoon.The chassis finish I am going with is Sterling Silver.:cool:
greatguy57078
greatguy57078
How do you guys plan on dealing with the windshield seal/gasket after chopping the frame?
I will leave that up to my window guy (high school buddy), but I would think you just need a OEM style gasket and modify it to fit the new opening.
greatguy57078
greatguy57078
We just finished coat #1 on the POR15. It looks good. Tomorrow morning we will flip the frame and do the bottom and coat #2 on the sides. When I get back home tomorrow afternoon/evening, I will do another coat on the bottom/sides again. This baby will look awesome by Sunday afternoon, when I lay down the first coat of Sterling Silver!:cool:
behemoth
Frame looks very nice that stuff is all over mine, I tried the semi gloss stuff and will not use that again. The basic gloss black has never given me any troubles.
I was attempting to get mine running and drivable for Fabulous fords tomorrow.
I didn't make it, obviously so I will slow down again and get some things done right the first time.
With these rims I need to run at least 1/2" wheel spacers up front to clear the a arms. I will get the part number of the longer wheel studs when I find one that works. The one inch spacers will push the wheels out to far into the fenders, hit a bump while turning and the fender is done.
Still lots to do,
