LOWERING my Bronco
greatguy57078
greatguy57078
What they say about POR15 and your flesh is absolutely true. It does get better with ALOT of scrubbing, but it won't be back to normal skin tone for awhile. I didn't know until I took my jeans off, that I had knelt in some that I had accidently spilled while pouring it from the can. By the time I got in the house and realized that it had slowly soaked through the knee of my black jeans, it was bigger than a large softball around my kneecap. I spent over an hour in the tub, motivated by the fact that I would have to go through the entire summer wearing jeans and no shorts. I wish I would had been as successful with my hands as I was with my knee. Although my knee is so sore and raw that it still hurts to walk. POR15 is some tough stuff!
behemoth
I have found this miracle stuff that takes por 15 off brakeclean. now this only works if it is not totally dried. give it a shot it will burn a little bit.
I tore a glove and did not know about it until cleanup, after all things were clean I removed the glove to find a black thumb. The brakeclean took it off.
Tito
CB Fire Starter
Bakersfield, CA
Hahahaha, ah the joys of por15! ;D
I had to do some serious work to get it off my scalp...didnt notice till I was washing my hair that night. Nice big heart shaped love spot left by the por15 :-*
greatguy57078
greatguy57078
Oh my! The frame looked great in black. What does everyone else think now that I went Sterling Silver topcoat? Give me your opinions! Shiney huh?:cool:
greatguy57078
greatguy57078
I tried to use the flash on my camera, but no way. All the pics turned out way too bright!:cool:
behemoth
Here are some pics of the mess at this point. Cover on and waiting for some more money to continue.
greatguy57078
greatguy57078
The money part is frustrating. If I hadn't been "collecting" parts over the years (reference my garage pics), my project would have been at a standstill quite awhile back. Just keep working on what you can, and research ahead of time on the items that you will be working on later. What you have got done so far looks great. Stay motivated!
greatguy57078
greatguy57078
Hey Bill. Could you share more info on your pics please? It looks like you have a custom crossover exhaust there. That looks awesome when you know firsthand just how tight those spaces get when you squeeze everything down low. Nice work!
I am getting real anxious to finish painting and reinstall everything. I am looking forward to doing some measuring to verify what tire I will be able to fit under the stock wheel well. It will also be great to see the front/rear and 4 link installed and ready for wheels/tires.
behemoth
The exhaust is a 2 into 1 2.5 setup. The Y is from magnaflow as well as the muffler. It is 2.5 all they way from the headers out to the tail. It exits on the passenger side corner hidden. It currently runs under the rear axle, but we will be changing that to go over. It was to tight to go over at that time but I will be re routing the brake lines to give more clearance. The going under is not a problem, but we did not figure the down travel well enough to get the tire off.
There is a custom transmission mount/crossmember to mount the aod to the bronco.
I will put up more info with the next round.
Take your time with the painting you will be much happier with it when you do. I hurried and had to re do things.
I have to find a magical 90* fitting that fits into the aod case for the cooler lines. NOT pipe thread and something like 13mm.
Then I can plumb the cooler and rear gas tank.
Then battery, cables, hoses,efi wiring, bleed the brakes, and......
Keep at it.
I am just slowing down now a bit.
greatguy57078
greatguy57078
Hey Bill...could you give me a pic of the notch where it ended up in relationship to the bed of the truck? Did it end up pretty close or did you have to cut it down any? I am just wondering, as I have not had my tub back on the frame yet.
I am still waiting for the body shop. The guy with the 30 something Dodge was supposed to pick up his rod yesterday, but last I heard was he was trying to find a trailer. I am hoping to deliver the Bronco today, so there should be some chopped halfcab pics coming in the near future. Back to work...
behemoth
I had to take an additional 1/2 inch off the top of the c notch as insurance. I also moved the back edge slope up 1/4 to clear the floor support. the floor support was not welded parallel to the others so one side hit and the other did not.
I am looking at ways to increase the slope of the windsheild to improve appearance. the stock un chopped one is starting to get to me.
It looks like it could be easily done with a custom dash, and notching the cowl to lay it back a bit.
bronko69er
EB Addict
Renton, WA
Awww man! Add another mod to my list! ;D
greatguy57078
greatguy57078
I have been thinking about the same thing. Even a little lean would be an improvement. I may have to compromise, as I want to have a small rake to the top of the halfcab also. I was thinking that the frame is getting cut anyways, so trimming the bottom/top and welding it back with a lean wouldn't be that tough...would it?
behemoth
I think improving the angle on the windshield would be the easy part. Modifying the hard top half cab or not would be the hard part. To me tilting the windshield effectively does the same thing as the chop to the eye.
The drawback to the tilt is the steering wheel to windshield and driver to windshield distance. It then could be too close to the driver for some and look funny.
A custom dash may not even required, just notching the back side out a little.
Now the hinge comes into play is it needed. Reinforcements could easily go down the kick panels.
Something more to think about again, photo shop will help as well with a straight on side shot.
bronko69er
EB Addict
Renton, WA
It really wouldnt take much work on the frame to get more rake. Just a slit in the base of the fram above the hinge and bend the slit closed and weld it up would net a surprising amount of movement at the top......
I plan on dropping the steering column and seats to floor level and running some low profiles seats (4-6") so the windshield rake would work just fine.
Its the added work on the door frames that make the mod more time consuming.
behemoth
Here is a shot of the side of the truck to play with the windsheild.
The front is set with a arms level, the rear has I believe the bags are empty and the axle is on the bump stops.
This is not ride height for the rear. I am thinking that I may just leave it alone and go back to the hood scoop option. Less work that way.
I have installed a bench seat from what I think is either a falcon or a fairlane it is split in the middle back . It fits really well.
In the pic I also have a dished steering wheel and the steering wheel lock. It looks as though I will be shortening the column again to get more space with this wheel.
greatguy57078
greatguy57078
Thanks for the update/info Bill. I have been busy painting and doing the usual yardwork that comes along with the warmer weather. I should have the 4 link back under the frame soon. Then I can move on to the Mustang II assembly work.
I dropped the halfcab off at the body shop. He wants to do the chop work on the cab before the whole truck comes in. There will be plenty of work to do while I wait for the chop. Updated pics to come...
