LOWERING my Bronco
greatguy57078
greatguy57078
Well I can see that the rake of the windshield isn't as easy as I had thought, but whats new with that? %) These pictures show where the cuts were made to get the bottom support to lay back so the rake of the windshield will line up with the chopped halfcab. I tried to get pics with the top and bottom half of the frame lined up but I had to snap these pics in between Gary welding.
77bronco_ed
I wish the thread had an index..
It would make it easier for us to use for reference ;)
greatguy57078
greatguy57078
I can't wait to take pics with the body on the lowered frame I have here at home. It is a small shop otherwise I would love to get some pics straight on from the sides.
77bronco_ed
Still a bit excited... I have been going over some of the dimensions mentioned in the thread and it appears that the dimensions on the frame section that I received with the welded hats and cross member has been set up similar.
The front hat dimension is about an inch larger where as I would need to take more material off the cap. (That is a good thing, the cap is at a larger angle that what you guys have... removing the additional material will make it appear similar to what I am seeing in the pictures-closer to being level with frame) The frame section is the same 4" (z height) 10.25 needs to be 9.25
The rear of the cap is about 1.25 over top of frame (1" minimum stated) and is approx 8 7/8"
I am just taking quick measurements to see if I should go through the trouble of cutting the parts off.
I did notice that this may be an older style crossmember and hats, or the difference is because it may not have been a universal crossmember/hats..
Although the cross member is slightly different in appearance I see no reason to be alarmed at this point.
However in looking at the hats you folks are using these look slightly smaller and do not reach the all the way to the inside of frame.
Are there any horizontal measurements that were used looking from top view. How far out should the large center hole be from outside or inside of frame and how far should the rectangular slots be from inside or outside of frame.
If these are similar I may go ahead and start cutting this apart. Can one of you guys scan and email me the instructions so I can get a better idea? I would hate to go through all the trouble of removing this and find out it just won't work.
Please see red mark ups on pic
77bronco_ed
Got up early this morning to do a little research on wiring. Slight difference, my compressor is 4wire 230 and I have my buddy's plasma cutter is only 3 wire 230. Got it figured out. Plasma cutter is working... It is going to be a lot easier cutting this frame and the parts off the bronco frame now!
behemoth
Stink bug is the rear sitting higher than the front, and with the short wheel base it is exaggerated. The difference on mine is actually only 2.5* but it looks like a whole lot more.
The hats in your cross member as well as the cross member are different and as you said that is because it is not a universal setup.
If you go to heidts web page you can download the installation istructions for all of their kits. the universal one that I ended up with was the 56" wheel base.
I would lower the mounts on the front 1"-2" in the front this would get you a nice level stance. If you wanted in the weeds then the drop spindles would fix that easily. To do that you will have to add the 2" to the bottom of the frame and then drop the top the same as there is a max measurement. Its been a few years.
behemoth
Mine is now on the road. No complaints, no regrets, it is what I was after. Its not done, needs a seat, paint, and some small details worked out but I have put about 50 miles on it. I have the sunburn to show for it, its been a fun weekend.
The lower links have been reworked and gussets added as the first thing I did was a 40' burnout. Jesse decided at that point I might do more with this thing than just cruise.;D The rear shocks were also relocated to get them more vertical and actually doing more work.
It drives great down the highway straight no pulling or wandering nice easy ride all over. Its also quick at 2920 pounds.
The exhaust is nice and quiet going down the highway, you could actually talk, but when you put the foot to it you hear it.
Its a 2 1/2 into one magnaflow round stainless muffler I love the sound, my other truck will have the same exhaust soon I think.
I removed the window frames and as I thought the proportions to me were corrected, looks good with no additional tilt. I am planning on running the stock unaltered hard top so I will not be chopping it.
I still need to get the seat and interior done as well as some other small things but I could not wait once I started it.
I am told also that I really should get a roll bar, as it is not safe, ha no different than any other convertible. So I doubt I will get one and if I do nothing more than a cobra style hoop for the driver and passenger.
behemoth
The air dam is a rear spoiler off of some type of volkswagon. It fits the bodyline width pretty well. It was free so why not.
Tito
CB Fire Starter
Bakersfield, CA
Very nice! Air dam looks damn good. Cobra style hoops would be slick. You planning on running a rear seat?
I need to stop by for a ride next time I am in the area, that sounds like fun!!!!
greatguy57078
greatguy57078
I like that alot. Although it really needs something.....ummmmm.....a Bronco benchseat I think! I would sit on a 5 gallon pail if I had to! Looks like fun to me Bill! Drive over to South Dakota and take me for a spin? :cool:
behemoth
I drove it around a bit without a seat sitting on a moving blanket and that was perfect. So regardless if a bronco bench is in its future it also will get lowered if possible. It needs the bronco bench badly this current seat is from a falcon and I really do not like it much.
Will see what happens, I new I was going to get crazy as soon as it started.
greatguy57078
greatguy57078
The newest pic. The welding is done. After raking the window back I might have to give up the defrost ducts. I am going to do my best to reattach the original dash, but no way without cutting something off the top of it first. I was planning on installing an older 66-67 dashpad also, but I may have to get creative now. Next week the final bodywork and primer on the doors and windshield frame. I hope he has the top section filled in by the next time I stop by with a 6 pack! I won't make it to Cool Deadwood Nights this year (with the Bronco), but we will make our debut next summer for sure!
behemoth
looking good, drove mine around tonight and I am liking it more and more all the time.
Starting to think about a radio as listening to the engine will result in a ticket sooner or later.
Does 100mph easily and is stable, the only issue is dirt any dirt gets in your face. I will get a pic of the speedo for another thread.
Lots to do yet still have only one brake light and no blinkers.
greatguy57078
greatguy57078
Yeah I learned that lesson with my very first Bronco. After that first "top down" ride. I bought one of those cheap little hand broom and dust pan sets, and cleaned out the truck as best I could after tasting everything that wasn't bolted down. :p
77bronco_ed
"The hats in your cross member as well as the cross member are different and as you said that is because it is not a universal setup.
I would lower the mounts on the front 1"-2" in the front this would get you a nice level stance. If you wanted in the weeds then the drop spindles would fix that easily. To do that you will have to add the 2" to the bottom of the frame and then drop the top the same as there is a max measurement. Its been a few years."
The front end came with drop spindles... I do not think I will be using them.
In the early part of the thread you mentioned there was not much room for adjusting heights due to needing min 1" above frame on hats, and needing to maintain the top to bottom dimensions. I do not really want to mess with modifying the front portion of the frame. I may be able to get the rear end down a little lower since I am doing a bit more than a c channel? Still have to watch the clearance of the rear end and truck bed...
-Ed
77bronco_ed
Looks good! At least you now start to enjoy the work, you can start on some of the other items on your list after having some fun.
I like the height, I think I'll just try to get the rear a bit lower...
Thanks for the feedback.
-Ed
behemoth
The rear suspension...
I have notched mine up to the bottom of the body with new bushings. I also have 1 1/2 bump stops. I could notch the frame higher by the bump stop height but that would be it. I would then hit the bed floor with the rear diff.
If you are going to narrow the rear frame rails I guess I would then look to go a little further and make the rear frame out of something shorter, narrower and get the rear clearance without a c notch. Where are you going to mount the gas tank ?
The lowering of the front suspension would be easy with the exception of the frame horns for the engine mounts.
If you choose to go the same route as I did I would recommend getting the standard spindles.
With the height that I chose I had to modify the front inner fender supports and remake the inner fenders. This was a time consuming expedition. The front suspension that I have is the 56" kit. Depending upon front rim size and backspacing you may have wheel to upper a arm clearance issue. Also I am running 1/2 wheel spacers in the front and I had to roll the fender lip to clear. Without them I clear fine. The spacers are there to clear the upper a arms and keep my turn radius.
Engine choice ? I inadvertently lowered the engine mounts. I used an explorer engine with a stamped steel pan and had plenty of clearance. I then installed my engine with the forged aluminum pan and I have lost some of the pan to rack and pinion clearance I once had.
A steering column out of a 67-70 ford f100 may be the correct length already. I shortened mine 7 inches to get the corrected steering geometry to the rack and pinion.
Sorry for the long ramblings, just thinking about some of the gotchas I hit.
