LOWERING my Bronco
behemoth
I sure would like a pickture of his innner fender clearance at ride height as well as wheel to upper a arm clearance at full lock one way or the other. As well as what upper control arms he is running.
Looks good, really good.
behemoth
Here is a pic of the interior, I had previously done the floors and now they are covered in lizard skin. Next it is carpet and seat.
The inner fenders are done and welded in just have to clean and paint things.
greatguy57078
greatguy57078
looks real good. think i may have made the bottom of the back window lower though.
I would agree. I am going to see if I can use the entire original window, althought that might be pushing it. It would look better with more glass there I think, and now would be the time to do it.
Here is a couple more pics that Dale sent me.
greatguy57078
greatguy57078
Looks great Bill. What are you using for a trans? The 4R70W? Lokar shifter?
greatguy57078
greatguy57078
Notice how much difference there is in the drop of the front end? Same front end assembly, but my rear end is set up differently. Mine still has the stock frame under it in the second pic.
behemoth
I am using the AOD from an 88-89 mustang with the lokar floor shifter. I modified it to use the stock mustang shift cable instead of the lokar linkage.
greatguy57078
greatguy57078
I actually have both of the 4R70W (99 Exploder)and the AOD (Versailles) transmissions. I have a TR3650 5 speed manual also, which is what I am set up for as far as the mount. I really love driving the manual shift, but that might change on this project. I hope to hit a few Bronco events, so the auto might be better for long distance driving as there is not much out here in South Dakota as far as Bronco events!%)
behemoth
http://www.youtube.com/watch?v=Xz0Elv1cHNw
This is the start up of mine, I had to stab the distributor a few times to get the timing right in the small space.
the exhaust is not completely hooked up or connected at this time it is a 2 into one then open so it does not sound right.
Only had two small fuel leaks before firing it up both fixed. Now since I bought the truck not running and re used some parts I have to figure out whats up.
Headlights do not work, the running lights do but not the headlights, I just installed a new dimmer switch as I lost the one that came with the truck.
The brake lights come on all the time, the pedal appears to be to heavy tripping the switch, disconnected the switch for the time being. The brakes have not been blead so we will see what it is like afterward.
Still a long way to go but I really wanted to start it to see if the engine was even a runner( bought it used).
behemoth
My wife was equally startled when it started the first time like that. Loud and not like what she expected.
Need to fix the oil pressure sender, l left the explorer one in there as I snapped off the bronco one on the other engine it had been a while. Now it is slightly more difficult to see and reach. Then I will run it some more before it goes back to the muffler shop to fix the exhaust.
Still need to bleed the brakes and work out the ebrake cables, speedo, and shifter indicator, alignment, headlights, then HID lights, cut the frames and a seat.....
But I can start it and that is what I wanted to do hopefully this will get me going again.
behemoth
Well now that my oil pressure issue is resolved i blead the brakes, that power motive power bleeder is the ticket.... it is fully endorsed by my wife.
They all run in my house when i mention brakes now I can do them by my self.
So still needs- ebrake cables, ebrake, alignment, exhaust, maf extension, a lower seat, headlight diagnosis ( they do not work), and the brake lights come on- its like the switch is to sensitive or the pedal is to heavy.
I am looking at this hood scoop and can not decide what do you think. Some thing different on something different.
Here is the latest long way to go yet but it is a good teaser and incentive for me to keep at it.
greatguy57078
greatguy57078
Not really a fan of that scoop.
I think that a scoop with straight edges looks better myself, but to each his own. I like the look of the old Mustang scoops. I will have to post a pic if I can find one.
On another note...how far back did you move the rear axle? I am just curious as I look at Dale's project and would prefer mine to be slid back 2-3 inches. Where did you mount your rear axle? What is the measurement as shown in this pic?
behemoth
The measurements on mine from frame to ground and body to ground are different not constant as I bagged the rear on mine. I can get you the wheel base and the back of the frame to axle center if that is what you need.
I basically pushed the rear axle back as far as I could go so that when the bags are empty and sitting on the bumpstops the diff cover just clears the rear crossmember.
They turn fine as the front suspension is only 56" wide, you may choose to roll the fenders as I will just for insurance.
I will be cutting the window frames off as the truck has been tumbled and they are welded on really good. At that point I will look at tilting the windshield a bit. the hinge on mine is new and is pretty tight so it actually sits up straighter than normal. That and i may have forgotten to grind a weld down.
greatguy57078
greatguy57078
How do those things turn without hitting the outer fender?
I am not sure if Dale has put his project through the full road test yet, at least driving it hard enough to see what rubs or doesn't. I asked (in his opinion) if there were any "PROs or CONs" about how this baby drives ... Dale replied:
"No con's, it handles like a sports car. It rides smooth and is fast like a rabbit on steroids."
DJFBronco
Southeastern Ohio
Wish I had been following this post since day one! I Have always loved this idea and will one day do it myself. If I ever did it I would have it in the weeds, mustang 2 front end with rack and pinion, notched 4 link rear with air bags, topped doors, no top and some sort of cobra styled windshield with the roll over hoop behind the seats! I don't even have my lifted bronco done and I'm dreamin of the darkside! We all suffer from a sickness! Praise the lowered:-X! Awesome trucks guys........Derek
Tito
CB Fire Starter
Bakersfield, CA
Are either of you guys planning to run any sort of cage in the Bronco? I know its lowered and risk is much less, just there is no upper protection in a rollover. If so I'd think it would need to be made a little different looks wise to fit.
