LOWERING my Bronco
behemoth
small update today.
The front coil overs are in much easier to install than the 13" long coils that I had in there before. Very light spring rate, a little concerned now on this route.
The main run of fuel and brake lines are done, the interesting part for the brake line was clearing the rear 4 link connection at the rear axle. There will be some fun with the fuel lines but not to that extent.
The fuel lines to the front are fun as well, I will be cleaning up the angles to the floor and run them up to the outside edge of the steering column support.
The fuel filter will be there attached to the brake booster and run steel braded hose from there to the back of the intake.
I need to pick up an external oil filter kit then install the steering lines and steering shaft.
The upper ball joint nut will not go tight, the ball joint spins before it goes tight, this may be another problemo.
greatguy57078
greatguy57078
Nice to see your progress. I hope to be right behind you in the weeks coming up. If I can keep from putting time and money into my S10 Chevy to keep it on the road for my son, I will be a happy guy!;D
Heus33
Looks GREAT - lets see some pics of the stance with those coil overs!
phred
Earth
Very nice work. Glad to see you are still problem solving and not butchering it to just finish it. Keep up the good work. Looking forward to seeing this on the ground.
behemoth
Well yet another change to the frame after it was all clean and painted. The rear shock mounts are going away for something more like what you did.
This way I can use a better rear shock and control things a little better. With the current setup and the bags empty the rear shocks were almost parallel to the ground.
behemoth
Here is where the hard lines ended up coming up the firewall. I will attach the fuel filter and the lines to the triangle column mount keeping them below the brake booster. I was going to use the explorer lines that come out near the front, but this will be cleaner.
behemoth
Well here is this weeks update on it.
The fuel lines are done, just need to shorten the steel braided lines and tighten them all up.
The tank is in temporarily I will have to remove it to pull the tape off and connect the lines and wire the plug.
I made a bracket with the bolts welded to it, slid it up into the frame rail and will bolt the tank to it.
behemoth
Well the break from the honey do list is over so we will slow down again. I was wondering how you and yours are doing.
greatguy57078
greatguy57078
Hanging in there. I have to keep my S10 running as well as everyone elses rig here. If/when I do have time I always have some other "chore" that needs to get done. I should have some time/money to get something done here soon.....I hope!
76 bronco J
>>>>> here's a link to what looks like a older build<edit:home page says it cruised the streets of Memphis in the early 90's ... I think it would look better with a slightly shorter top.... last 2 pics were the end of it's life before being parted... builder says qoute >> " I had procrastinated fixing the wheelie bar/fuel pumps interference problem for too long this time as it was a violent wheel stand that steered me into a concrete light pole just before a street race for $2500 against a Memphis heavy hitter, Don Gingrich. I heard that there is a video floating around the country. Fortunately, I had my helmet on, which helped protect me from the flying concrete. Due to the amount of money invested already in the Bronco, I decided it was best to just part it out and cut my losses. If only I had put those wheelie bars on."
page 1 http://www.sleeperbu.com/Bronco.html ... page 2 http://www.sleeperbu.com/Bronco2.html
Kyle.malone
Norman, OK
I really like the way the front end turned out..
Glad to see (hear) that no one got hurt.. I am just not a fan of a lowered bronco
behemoth
That one and the turquoise one here in the san diego area are the ones that started this mess with me. I am not sold on the half cab look even on a stock truck.
Here are some pics of the one from the for sale section.
73stallion
Eugene, OR
well i talked to the older guy who owned it a few years ago, he was trying to sell it for $41,000.00. he lived in temecula, and he wanted to sell it to someone who lives somewhere besides cali. he didn't want it in the area anymore, sentimental reasons.
behemoth
Small update today,
I bought a lokar floor shifter for the aod. I swapped in the lokar shift arm into the transmission and when I installed the stock aod tv arm I was not happy.
There is no way to use the lokar shift arm and the stock aod tv arm together.
So I put the stock one back in, now there is no way to use the lokar shifter with the stock mustang aod shift arm.
So I modified the lokar to use the stock mustang cable shifter. I only made a new arm to attach to the lokar. The cable mount was fun.
Here are the pics of this mess. It works so no complaints, just a long day under the truck.
I also attached the remote oil filter and got that part all dialed in as well. I will probably change out one of the hoses for a longer one before it ever starts.
LilRedBronco
Belmont, California
Great thread and timely... I have been contemplating building a "Rat rod" and that progressed into hey why not lower an EB put a big ole honkin street engine in it and do something different.
Ordinarily I look at lowered trucks and think what a waste but lately I have had an itch to do something out of the ordinary. Still thinking but this thread has given me lots to think about so thanks folks...
I have to admit I chuckled big time at the sleeper Bronco picture series on this page (39) I was slowly scrolling down looking at the progression of the build like I normally do and then BAM up scrolls the picture of it trashed in a wreck. Not that the wreck was/is funny but it certainly wasn't your normal progression before and after type picture series.
I'll continue to follow the thread this is a great forum because of stuff like this. Folks willing to think out of the box and other folks willing to let people do it without being ugly. I have read threads on other forums where guys can't resist saying crappy stuff when others dare to be different.
Nicely done folks.
