LOWERING my Bronco
77bronco_ed
I am glad you decided to remove the higher section of the floor. This is what I have planned as well. In addition, I am moving the entire lowered floor section a few inches further back (aft). There will be a similar 90 deg step however it will tie directly into the new higher height established for the rear floor pan. I was hoping that by removing the higher portion of the front floor pan that I might be able to get a little more radical on the chop. I hope you get to this first, I can use your "lessons learned"
Keep posting progress!
behemoth
With lowering the floor sections and standing the bulkhead straight up the middle body mounts will need to be removed/moved. I also believe that the frame under that part of the truck also starts to taper uptwards the body at or after that middle body mount.
Then isnt there the supports for the rear fenders also in that area under the truck that will need to be adjusted.
the steering column, if you shorten it, pulling it closer to the dash that will also lower it in the cab. Then with the tilt you should be able to get under there better. The 70 ford truck steering column is also much shorter than the broncos so all you would need to do is move the mounting bracket.
I found this out after shortening my column and machining the steering shaft.
greatguy57078
greatguy57078
Good points. I will have to look closer at that. I have pics from another member here that did his floor the way I woulld like to do mine. I will try to post the pics.
If the other column is that much shorter I should be able to put it just about anywhere I want with the new drop mount. I figured I would just move the firewall support down to accomodate the new location.
greatguy57078
greatguy57078
This is how I would like to do my floor. I don't see how it would interefere with anything major, but as I said I will have to look more closely at it to be sure. Some guys say "build it for YOU", but if I can only allow short people to ride it in that would take some of the fun of doing this project out of it.
The first pic is the one that I "borrowed" from another member (thanks _____!) The second pic is of the floor the way I will be attempting to do it. The third pic is another one I "borrowed" showing how they stood the bulkhead straight up.
I have wavered back and forth on the 4.6 DOHC engine, as I would really like to get this running this summer. My father-in-law has bugged me for a couple years to "stroke that bitch". This has been a dream of mine for years, ever since I saw that low halfcab that Duffy used to have on their old catalog years ago. I am REALLY itching to "get 'er done!":p
behemoth
In these pictures they did not lower the floor back to the point where the body mount and frame become an issue. I thought you wanted to lower the floor further back than the bulkhead bolt line( body mounts also). With the floor this way in these pics you are limited to the same distance for the seat. It cant go any further back than stock seats do to me.
Im 6 2 and with the new prp bench in mine I sit much lower and it is actually pretty nice. I did not lower the floor but I mounted the seat basically right on it with the front a little higher.
the pickup column may work well to shorten and correct any steering angles to the rack and pinion. It also would give you more engine clearance with that fatty 4.6 going in.
greatguy57078
greatguy57078
I would love to see pics of the new seat you installed. Sounds awesome! I have had no luck locating the VW spoiler you used. It's an aftermarkt part made in Germany. Some VW guys think it might be for a Golf, some think maybe a Rabbit? That is all I have been able to find out about it.
behemoth
i found one once online, I will look again and see what I find out as well as ask some local vw people what they think.
Seat pics to follow, the color is a little off and I think I will have to change it.
L&D's Broncos
This has been a dream of mine for years, ever since I saw that low halfcab that Duffy used to have on their old catalog years ago. I am REALLY itching to "get 'er done!":p[/QUOTE]
You know that Jim Restored that Bronco several years ago right? It will be out again this summer at a few Bronco shows. Not sure of which ones yet?
I will keep looking I have pictures of interior close up somewhere, the floor is not flat but higher. The whole floor is the same depth as the floor under the driver's seat of a stocker. Look at the picture of grill head on...bumper is in stock location on end of frame. Fan blade is on END of crankshaft, not water pump. Body was LOWERED over floor pans. Bronco Driver did a story on this while it was being built something like 2003' or 2004' ??
I had planned for years to do a lowered 1/2 cab but life and kids got in the way......on a sidenote, I had special wheels made by Centerline for mine but were never mounted, I take it you already have tire & wheel combos already?
behemoth
its a prp bench seat from prpracingseats.com. It is 56" wide and it is I belive 3" shorter than what they offer. The white color is a little off my fault not theirs. It sits low and just fits in the truck, I also am sitting much lower in it as well.
the side shot is before the seat, and window frame removal but it is as close to my chosen ride height as I can find. I am still looking at that scoop for some reason.
greatguy57078
greatguy57078
Man I like that! You have great taste. It seems to fit the overall concept, at least for me. The color doesn't look off either, at least not at 4:30 AM! Off to work! :cool:
I personally would look at something with more straight edges for the hood scoop like a Mustang GT scoop. In the end it will be what YOU like. So far I liket it. Good job!
yak67
I've been wondering if one of their benches would work up front in an EB, now I know.....looks really good.
behemoth
Its 56" and I think I would go 55" to allow more room between the doors. I will also be looking into having them make a removeable armrest for the middle seat area. something with some storage
77bronco_ed
In these pictures they did not lower the floor back to the point where the body mount and frame become an issue. .
I will be moving the front floor back in mine... I am already moving the middle mounts back to the new body crossmember (new height for bed)
Once the rear is semi complete I'll begin to cut additional flooring out.
77bronco_ed
Thanks for showing the side shot showing the rake ;) Seat looks nice in there!
I really like that steering wheel, I plan on going with a nice wood wheel in a couple of my trucks. Nice look!
We are all trying to do things a bit different. I decided that I will attempt to leave the vent windows in for the chop. Might add more work but I am trying to keep the stock look as much as possible. Even though it will be heavily modified.
Keep on it Marty!
greatguy57078
greatguy57078
Well I am making progress. Slow and steady but progress all the same. I got the two front body bolts out, and snapped the back two off. THe floors are rusted in the feet area, so I figured those would be removed after I pull the tub off. I was dreading the two behind the seat area, so I saved them for last. To my amazment, they were the only two that gave me absolutely no problem. They came out like they were installed using anti seize.
I cleaned out the bed area completely ridding it of the 40+ years of dirt (and whatever else) that had accumulated behind the gas tank that was mounted behind the bulkhead. Hopefully I can get a couple buddies over here this weekend to get this tub off and set it on the streetrod frame. Then we can see what kind of stance this monster is going to have! %)
behemoth
pics pics and more pics, I enjoy seeing these things built almost as much as building mine. I am really curious about the front inner fenders my self since I had issues with mine.
I am still contemplating a change to coil overs in the rear but not any time soon I guess, funds are not there with the kids requirements this year.
I went after mine friday with rubbing compound and a buffer, then again on saturday. It is much better, but there is no helping the windshield frame.
Now I am working on the ebrake cables using the explorer cables to the bronco front cable. Shouldnt be that bad just figuring out the mounts for the cables to keep them out of the tires and other spinning fun.
greatguy57078
greatguy57078
Well another 6 day work week, so hard telling what I wil get done tomorrow. I go in at 5AM every day, so maybe I can take off early and turn some of my own bolts. I wil finish disconnecting everything to be able to remove the body hopefully in warmer weather next week. Now my son wants to drive the '68 to prom, so that will have to be cleaned up and the brakes gone through also. It's always something. %)
On another note, I had a few moments to myself on break this week, so I took advantage of that time to design my dash overlay on CAD. I did not dimension it out, but it is drawn to the correct size. I will be cutting this bad boy up on the big CNC mill we have. I am not entirely done yet, as I have a few more tweaks to add.
behemoth
on that below dash center console, check the depth from the dash to the heater box in the center. I was going to do a console and put the radio there but I did not have the room. I was going to recess mine a bit below and underneath the dash. Just something to look at in case your doing something along those lines.
greatguy57078
greatguy57078
I am leaning mine back away from the bottom of the original dash. The design I am showing is just a 1/4" aluminum overlay. I am looking for something a little different than just a plain flat dash. I have a rough idea here somewhere that I did using an pic and Paint. I will be doing something along the same lines but a little differerent with my 4x4 Bronco, retaining all of the original accessory knobs/locations.
