Today was my third attempt at running my new Ford crate 5.0 (GT-40 aluminum heads) and for the third time I had to shut down due to a coolant leak into the intake on the passenger’s side (clouds of billowing white vapor on the passenger side exhaust).
I’ve done many an intake manifold and usually get the water passages sealed, if there is a leak as there can be with Edelbrock Performer 289 aluminum intakes. (Incidentally I am running a carb until I finish cobbling together the remainder of the efi components, so that is in the works.)
Nothing I do seems to fix this one: I have read all the previous threads for insights on sealing issues; carefully thought through all the likely places things could go wrong with the particular head-intake combo; used the Ford Racing gaskets, the Fel Pro 1250 gasket; used hi-temp silicon on one side of the water passage, on both sides of the water passage; always torqued things in stages as per specs for the aluminum heads and intakes and re-torqued after a few hours just in case; all the usual gasket adhesives, including thick beads of silicon and thin beads of silicon sealer; used studs to carefully lower the intake into position; let it sit for day and let it sit for a couple of hours before adding coolant; checked to make sure the intake is “key stoning” into its seat squarely; checked to make sure the gasket adhesive is doing its job and that the gaskets are not moving or out of place; drained the oil and refilled with new filter to avoid contamination each time; and even got a new intake just in case there was a warp, crack, or machining problem with the previous one.
In short, I have carried out a pretty thorough program of experimentation for obtaining what I hope will be reproducible results. From try number one to try number three I have succeeded in getting the sealing problem to move from both sides to just the one side. But it still leaks. The last attempt was done with all the care of brain surgery. I am aware of how tricky intake sealing can be, but I think that I have used up all the likely options. More important, if this one is that tricky, I worry about ever removing it in the future for fear of not getting the magic sealing incantation back. If my program of analysis was not good enough by this point, I confess to being a little stumped.
I guess I am looking for some thinking outside the usual box.
