wmish
All right I've finally gotton sick and tired of my 3 on the tree set up. It falls out of 2nd gear going over bumps and it is forever getting stuck in 3rd gear because the shift linkage binds up on its self. Now the Retaining clips have broken off the shift linkage (I know easy fix but I'm looking to improve the situation).
Is it possible or even worth fixing the column shift linkage. I have read on this board about rebuilting the column. Has anyone else dealt with this problem if so was a column rebuild the fix? or should I just go with a floor shifter?
Are the floor shifters more reliable? I've heard a lot of good things about Duff's Original 3 speed shifter. With the exception of cutting the hole in the tunnel is this mostly a bolt on type of project? Does anyone have any pics of the mod?
Bill
Bill
