Manually indexing non-fully indexed pitman arm
ksagis
Aspiring Bronco Guru
Austin
Are people just fully removing the keyways or trying to make splines when doing this mod to a non-fully indexed pitman arm?
Seems a lot easier and straight forward to completely remove the keyways.
I see a lot of posts about using a triangular file so began to wonder.
Many of those posts are mine.
First time I installed Pitman Arm meant for a full size Ford truck on my 71 bronco, the arm lined up too far off to one side. So I decided to at least try to knock out the keys to get better alignment
Tried the triangle file cause it looked like the right size in shape. Turned out the Pitman Arm was not that hard of metal to begin with, and it only took me a few minutes on each key to turn it into a regular spline. Or at least close enough…
Then I could install the arm in any position I wanted.
Those are just for ansse I believe, and getting it in the same place every time. They don’t have any necessary strength advantage that I’m aware of.
Besides, if an arm doesn’t fit the way you want, what do you have to lose?
K
ksagis
Austin
Thanks for info Paul.
I was thinking (assuming there is a taper on the sector shaft and pitman arm) that it would be hard to get the angle of sector shaft and the spline shape correct, such that it’s better to remove the keys entirely.
i.e. to avoid binding during install and future removal pains.
The only downside I can think of for fully removing the keys is some reduction in load capability so leaning that way.
ntsqd
heratic car camper
Upper SoKA
I kind of doubt that 3 or 4 splines difference in strength is going to matter, especially since Ford basically threw them away with the keying.
You are correct about the taper. So I guess the answer is either, be careful how you file, which is always good idea, or, as you suggest, hog it out a little extra. I prefer just being careful and test fitting it a few times.
Might not be super accurate, but it should work.
And when all is said and done, and the nut is torqued down the final time, check it every week or so for a few weeks.
Assuming you’re driving it regularly that is.
If not driving regularly, then carry a big adjustable wrench with you and when you do drive it, check it after 20 miles or so.
jamesroney
Fremont, CA
Yeah, you are over-thinking this.
Get a triangular file, and cut the "missing" spline. I usually cut a guide notch on both ends to help keep it straight.
Yes, you need to file at a 7 degree taper. No, there's no problem with going a little too far. Yes, it is a lot easier than you think it should be. Pitman arms are mild steel, and file quickly.
Many people aim the pitman arm straight rearward. The Factory installed the pitman arm to align with the drag link when pointed straight ahead. So you should be able to put a socket and long extension directly above your drag link nut.
If you put it together "correctly" it looks kinda silly.
