The 1990 Mark VII is a speed density HO motor, but it uses a different ECU and wiring harness then the Mustangs. Basically the engine is the same except for no mass air meter, but the wiring and computer are different.
If you plan to pick up a RJM wire harness, mass air meter and a Mustang ECU it will be a easy swap. It is possible to make the Mark VII harness work, but it is much more involved than adapting a mustang harness.
