Aptosgrown
Been reading through as many hydroboost posting as possible and have come up with a couple questions before I dig in. Hydroboost guru's I need some input.
Has anyone here used a hydroboost from a Mark VII, I was able to pull one from a 1984 at the yard the other day. This hydroboost mounts via 4 bolts through through the firewall. Do I just drill the firewall and mount, or should I make a plate like many others have that have mounted hydroboost? Mount the boost to the plate and then plate to the wall? I do want to install it perpendicular to the firewall, no angle bracket.
Second, I have heard mention of relocating the hole through the firewall a bit due to manual column setup, which I have, the power source is a 302. Does this relocation sound needed?
Third, I was planning on just using a 1984 Mark VII MC, any reason not too?
Lastly, If I do need a mounting plate, any ideas who could help me make one, or whom I could procure one from?
These are just my initial questions, I'm sure I'll have more once I really get into it. Thanks!!
