mark vII 5.0 hipo
daves bronco
Bonney lake WA
So my bother gave me a 88? lincoln Mark VII, that he was not going to use. It got lots of good parts, air bags for dads hot rod, aod tranny and a 5.0 hipo engine. Has any body put one of these in there bronco. Plan on putting it in my trail rig. any thing I should know or avoid doing or is it even worth it. One of the cool things about it is it has a engine mounted compresser, for the air bags, I can use to reinflate my tires.
OX1
The harness is a PIA to use as it has a lot of things embedded in it that are not realted to the EFI. It is a speed density HO motor, so it is a good candidate for a swap, except the accessory package does not fit as well as an explorer setup.
I used the rear calipers on my 70 EB (with 94+ 1/2 ford 5 lug rotors) on my 9", but most go with a complete explorer and or caddy calipers.
77TnBronco
Kodak Tennessee
*Off Bronco Topic.
Save the rears discs,calipers and caliper mounting brackets. Also the any pins or clevises. Axles are too long, so scrapem.
Mustangers use these to swap off the drums on any 8.8 rear to keep Fox width. You swap bracket sides which moves the calipers inward to line up perfect for Ranger/Aerostar axles = Fox width with 5 lugs.
Those calipers are like $70 core each.
I did this swap on my Factory Five Cobra rear.
