OK, here's the deal on the mass buy for the BC Broncos gas tank.
What: 24 Gallon rear fuel tank through BC Broncos
How much: Tank w/ skid plate $310 (normally $375) or tank w/o skid plate for $279 (normally $310) + shipping + tax if you're in California
How many people: We need a minimum of 20 people to make the deal go through
How long: All orders need to be placed by Friday, Oct 18th.
Payment: All payments will be made directly to BC Broncos so that a third party doesn't have to be in charge of your money.
If you want in on this deal please email fetchin at elioart1@yahoo.com with the following info:
Let me remind everyone that the only way a mass buy works is if everyone who says they're in is really in. So do not add yourself to the list unless you are absolutely, positively and without a doubt sure you'll be buying one. If you say you'll buy one and then don't you could ruin it for the entire group. :-U
Here's the description of the tank and skid plate as taken from the BC Broncos site:
The ultimate Early Bronco fuel tank is here! Newly re-designed with cleaner lines and an ingenious new mounting system, this replacement fuel tank is designed to withstand years of hard-core four wheeling. The new track-mount system allows you to mount the tank in any Bronco, regardless of body lift, as high as possible to get maximum ground clearance. This tank is designed to take advantage of all available space to maximize fuel capacity, increasing your range. The kit includes tank, mounting bracketry, sender, hardware and instructions. The optional skid plate can be bolted on.
If anyone has any questions post them here. Thanks!
- What is your measurement between frame rails at the tank? Looks like some EB's vary.
- Do you want one with or without a skid plate?
- Do you need filler and vent hoses? ($15 for the set)
- Your name, phone number, email and full mailing address with zip code to calculate shipping cost.
