Guys,
I have been in discussions with the disc brake guy on ebay, who only has 2 negative responses and those were basically bogus. Here is a mass buy where we get to tell the vendor what we think is a fair price for his products!!! These types of buys RARELY come along, if ever. I only need 2 other participants to commit for this to be a 'go', but will take everyone that definitely wants to participate. This mass buy is immediate for the first 2 guys that sign up, and for those that straggle with your decision there will be a delayed mass buy order placed in the near future. So, lets discuss what we think should be a fair price for the following kit: (He'll also add the master cylinder & proportional valve if interested). By the way, this kit is currently for sale on Ebay and it has been bidded up to $455.00
This front Disc Brake Kit works great on any Bronco, 66-75. It is ready to bolt on, and easier and cheaper to do than some other kits which involves changing your knuckles, ball joints and tie rods. Your Bronco's stock front wheel bearings, spindle nuts and lock-out hubs will all work with this kit. ALSO, you can install this Disc Kit on a dana 30, and if you up grade to a dana 44 you can just transfer it over!
This auction is offered with 2 new take-off Spindles, the bearing surfaces are in excellent condition. Also included are 2 new take-off Caliper Mounts. This Disc Kit now comes with Steel Braided brake hoses, D.O.T. certified. THIS SET INCLUDES: Easy to follow INSTRUCTION Guide, 2 Brand NEW precision machined & balanced HUB&ROTORS, made in USA, 5x5.5 stock bolt pattern with new bearing races factory installed, and 2 factory-rebuilt, 100% tested CALIPERS with all new parts including new pistons, and 2 take-off CALIPER MOUNTS, and 2 new take-off SPINDLES (Dana/Spicer), and a new set of Semi-Metallic Disc Brake PADS, and 2 new Steel Braided BRAKE HOSES, and 4 new caliper GUIDE PINS, 2 new BANJO BOLTS w/crush washers, 12 Spindle MOUNTING BOLTS and Lock Washers, assorted hardware, 1 can of PREMIUM disc brake Grease, and all new OIL SEALS.
REMEMBER, with this Kit you do NOT need to change your Knuckles, Ball Joints and Tie Rods. This Disc Conversion Kit comes complete with All the necessary Hardware and Instructions. Let me know if you have any questions.
