In addition to what's listed you'll need:
1. Brake Hoses, stock ones for '75 Jeep Cherokee (or what the calipers come from). ($35/pair)
2. Banjo bolts to mount the hoses to the calipers. **
3. Brake pads. ($15)
4. Caliper bolts. **
5. Oil seals, $5.
6. Bolt/washer combo, free.
Get a guy like me who sells the used spindles/backing plates and I include the caliper bolts and banjo bolts. I usually sell sets between $100-125, depending on shipping. Then the hub/rotor set was $35/side.
Optional parts are:
1. New wheel bearings. The hub/rotor assy comes with new races installed, so you can reuse your old bearings if they're good, or spend another $35 or so on new ones.
2. Longer spindle mounting studs. The Ford ones are a little short with the Chevy spindle, not 100% required, but if you plan to wheel the truck then get them.
3. You can get the Chevy outer stub axle and use it as well (if you're already running the 297/760 size joints).
Total is about $250 for the basic stuff, then add if you need new bearings (which he doesn't include) or if you feel braided stainless lines are better than OEM.
