'73, been sitting a long time since last run.
Got it cranked last night... took a lot of priming @ the carb... discovered the oil is milkshake colored and wreaks of gas... pulled the opiil filter, full of wattery gas. Yuck.
So I'm 98% sure the mechanical fuel pump is toast. When it was running, when you pressed hard on the gas, it would die, like flooding. I'm assuming the pump diaphram is bad and it wasn't getting decent pressure while also leaking into the oil.
THANKFULLY it hasn't been driving like this.
So 3 questions.
1 - any advice on replacing the pump? The power steering pump looks like its really in the way... does it really need to come out? Am I correct that there are only 2 bolts (and a gasket) holding it (fuel pump) on?
2 - Any reason its worthwhile to get a "fancy" pump from Holley etc vs the Airtex $30 job?
3 - Advice on flushing out the engine? I'm thinking fresh oil, add an emulsive, run a little while, drain, new oil again, run a little, see how it goes.
So 3 questions.
