Has anyone ever adopted a modern, in-tank fuel pump module to their Bronco fuel tank for EFI? I have been doing a little bit of research and a fuel pump module from a 1998 Chevy Silverado looks like a great candidate, something like DELPHI FG0085 (see picture below).
You can get these pump modules relatively cheap ($100-150), they have a built-in sender (will only work with 250-40 ohm gauges), simple supply and return connections, and a nice o-ring seal. Best of all, the factory quality pumps have what is called a jet-pump built into it - this is a device that keeps the bucket for the pump full of fuel. The jet pump is why factory pumps are so reliable, and why you can run modern cars almost to empty without fuel starvation. The pump also runs cooler and is muffled because of the the bucket of fuel.
I'm looking at the Chevy pump for having a return line and no emissions add-ons, and were used on V8s up to 454ci. They are about 15-16 inches tall and will compress to fit firm to the bottom of the tank, so they should match a 23 gallon Bronco tank well.
I also found this adapter that can be welded to the tank to make the factory o-ring work:
