Modifying the Duff Torque Tamer
JWMcCrary
I need to relocate the crossmember for the torque tamer about 3 to 4 inches farther back on the frame. The attachments to the axle are fixed and the adjustment is not going to allow the shackle part to reach after I move it. I think the torque tamer bar would still clear but is close for comfort. I need to make longer shackle connection or shorten the end of the bar 3 to 4 inches, or possibly both. Does anybody see any problems with this modification and it still functioning like it's intended? I really want this back under there as all my wheel hop went away after it was installed. Been running it a few years.
If I put the crossmember back in original location I hits the plug for putting in gear oil.
edit - sorry, pic is upside down, tried unsuccessfully to fix
01Dudley
Knoxville
So I guess my first question is why is your transfer case back so far? None the less I would suggest cutting 3" out of the tamer before making longer shackle. 2 reasons. Longer shackle will allow the tamer to pivot more / roll axle more and you might get a touch of wheel hop before the roll of the axle stops. 2nd reason the increased length of the shackle might get into your floor board.
Buldozer
Bronco Virtuoso
God's Country
I am not sure what you ended up doing on this JW, but I wanted to say that so long as you have the linkage tight your not going to get any wheel hop IMO. I have had a lot of problems with breaking drive lines and ended up removing my wrap trap and installed a torque tamer. But I had to modify the torque tamer to make it work. I have all 1350 drive lines and when I installed the torque tamer, I put it on with just a stringer and took it out to flex it and see how it would work since it was close to the drive line and it actually broke entirely off of the rear end when it flexed!! :eek: So back to the drawing board and I cut off several inches and installed a 3/4 heim that can flex, sliding on a hardened 3/4 bushing so it has some room to move when it flexes also. This seems to work fine and provided more rigid up and down support than before because the heim does not give at all where the bushing did have some play up and down. Here are a few pics.
JWMcCrary
JWMcCrary
It's at the muffler shop right now getting the exhaust fixed to clear the new location for the crossbar. Then I will know how much to shorten it, I'm thinking about 4 inches.
Buldozer
Bronco Virtuoso
God's Country
I ended up cutting 2" plus the end off of mine and it seems to work fine so far. I guess we will give them a good test at OCBR......;)
JWMcCrary
JWMcCrary
Cutting 3.5 inches off of mine, got the crossmember mounted this weekend so I could get a measurement. I don't have a way to cut and weld here so dropping off the bar at a machine shop close to the office today.
NYLES
Question 1 he running cold duck
