- Apr 3, 2022
- 679
Folks, as you all know I have been a OP on a few fairly long and super helpful threads regarding caster/alignment issues. One more (maybe the last) question for you all to ponder.
As most of you know, I have a completely restored 72.
WH 2.5" SL (no BL)
33s
All new steering components
WH quick ratio PS system (included new steering shaft as well)
IDIDIT column
7* wedges
Eccentric Ball Joint inserts
Caster is 4.3* both sides
Toe-in is .2 total
However, driving this weekend again made me think this cant be right. I seriously would not want my wife to drive this thing. Its fine going straight down the road, but on a curve or going over a dip while in a curve it could easily cross the center line if you weren't double gripping the wheel.
Many suggest caster at 4.3 should be just fine. I'm thinking based on how it drives it should be more like 8*.
I know I should have cut and turned the Cs, too late. I can install lowering radius arm brackets?
It just seems like the steering is way too responsive. Like I wished the steering box had a way to "tighten" up the action...could the WH quick ratio box just be too reactive?
I'm at a loss here but need to try something...only thing I can think of that would be fairly easy is to weld on the lowering brackets. Thoughts/ideas?
WH 2.5" SL (no BL)
33s
IDIDIT column
7* wedges
Toe-in is .2 total
