Being the original poster of this thread I have a few observations given all of the input.
1. There are folks in this community that have forgotten more about this subject than most of us will ever know.
2. 7* caster is optimum.
3. Cutting and turning Cs is the right way to fix it.
4. Solutions other than cut and turning are less than optimum.
5. Several other steering components play a part in drivability (none as much as caster).
Important to also recognize a few other considerations.
1. Not every owner has a shop to cut and turn, weld, and install the front axle.
2. Not every owner has the funds to have someone else do that work.
3. Not having the ability or funds does not detract from still wanting to improve drivability ie. leading to other “less optimum” alternatives
4. C wedges, eccentrics, drop arms, etc all improve caster when “the best options” are not attainable and thousands of folks have nice drivable rigs due to these creative alternatives.
5. Folks should do what they can, to whatever ability they have, as long as their decisions are based on good knowledge (obtained in threads like this).
For me, I have a shop, the time, and funds to cut and turn…but at the time I was building the front axle, I did not have the knowledge. I will likely cut and turn eventually, but I’m also very interested to see what effect a drop pitman and bracket will have…that knowledge may help those without the cut and turn option.
Great discussion!!!
7 degrees of caster is the minimum for 33'ss. You get some additional centering force from the contact patch centerline moving forward with bigger tires. So with 35's...you can get away with 6.5 degrees.
The Big Mercedes, (and the Maybach) set factory caster at around 11 degrees. Those are big, nose-heavy rear wheel drive road floaters. They soak up miles on the Autobahn, and rarely do anything remotely resembling a dart. The more sporty BMW 7-series runs right at 6.5 degrees.
Someone at Ford decided that it was more important for your 10 year old to steer the Bronco around the farm than to drive the Bronco to the farm. In a cruel twist of fate, the alignment specification number was published in a book. For some reason, Ford Motor Corporation, their entire engineering team, and every automotive alignment expert seems to have more credibility than me.
Keep in mind that these are the same idiots that gave you a Dana 30, 28 spline rear axle shafts, ignored power steering, and didn't discover disc brakes for over 10 years.
You absolutely do NOT need to cut and turn to improve your handling. With Jim Cole's caster compensated radius arms (you call them Duff arms) and 7 degree bushings, you can get 11 degrees of additional caster using your factory un-cut housing. You just can't put a driveshaft in it.
For the truly agnostic, I remove the front driveshaft and bring the front end to 7 degrees of caster. If they like how it drives, then we cut-and-turn.
