from a Viperwolf1 post:
Seals:
Input shaft seal (double lip)-CR #18676, Timken #473179
Output shaft seals-Timken #450185
Shift rail seals-CR #6204, Timken #471466
Bearings:
Input- SKF #307NRJ
Rear output-Timken #25877 (inner), Timken #15117 (outer)
Front output, J shift-Timken #14116
Front output, T shift-Timken #14131
Cups:
Rear output-Timken #25821 (inner), Timken #15245 (outer)
Front output-Timken #14276
When setting the rear output endplay use a Timken #15118 in the rear position. It is the same size as the #15117 except the inner bore is a couple thousandths larger. This allows you to assemble and disassemble the output shaft without needing a press. Only use it as a setup bearing. Once the correct endplay is set assemble the shaft with the #15117 bearing.
