I found a full width 44 out of a later model bronco but it has cast wedges and not weld on what is the negative to that i know that the coild springs will bow a little but couldnt i just move the coild plate over a little. I have WH extended radius arms right now will those work i notice a lot of you guys with full width axles are running cage extended arms. What is the best way to center the axle front and rear? And how do i measure what kind of shims i need for my raerend my drive shaft is at a very steep angle with my 4bt zf np 205 set up.
Thanks again for all the great info
