More Full Width Question
kyle
So I have read some of the post on this topic and I am still left with the same question.
I know that I am going to run a HP 44 in the front of my 69. I currently have it tore down to the housing, and I have a shop that will narrow it for a decent price when they install the gears. It has welded wedges so should I choose to run full width I could easily move the wedges in, but what is the advantage of doing that as opposed to narrowing the housing? I could get a wider stance by running less back spacing on the wheels so is there a real advantage to full width?
This Bronco is going to be street driven to were it is going to be wheeled so there is also some concern about being somewhat close to legal.
68beast
Covina, Kalifornia
If you leave the full with axel the length it is now, the tires will stick out about 4" on each side further from stock. Other advantages to this include cheaper replacement axels, and more clearance between the radius arm and tire, which is important for turning with large diameter tires. Plus I believe if you get less backspacing there will be more stress on the knuckles of the axel making them wear out quicker. As far as street legality, some mud flaps on the rear of the vehicle should satisfy most state laws I believe.
Hope I helped, happy wheeling!
If you are just trying to compare a wider axle housing with normal backspacing vs. a narrow axle with offset wheels. Both will get you the wider stance. But the offset wheels place a lot more leverage on the spindles, bearings, steering linkage. The scrub radius is way off. If one tire has a good bite, it will want to pull harder on the steering wheel as well (part of that scrub radius thing).
Ideally, it you turned the steering with the vehicle stopped. The centerline of the steering pivot should run through about the center of the tread pattern. This minimizes steering kickback. Go a little deeper into theory and camber loads the tire slightly differently between inner and outer tread, so offset this pivot point to center it in the tires load patch with the ground. Throw in a bunch of other compromises to make everything work and you have an acceptable behaving vehicle.
welndmn
Maulo ah something, Pontiac used to say it, wider is better.
EB's have 60 inch wide axles, where full width is 65 inch.
Thats 2.5 inches per side, nothing to worry about.
Go full witdh that way you can easily get spare parts.
