more steering resistance
Crawdad
Do you guys feel the steering angles are too much? Would a drop pitman arm and dropped track bar help?
Hmm, I guess I didn't see bowsher's input before posting. He's got it all down there so I'm just duplicating some of it.
It's what happens when you read, start writing, then go deal with the usual family emergencies before finishing things up.
I try to remember to refresh first, but get on a roll. You've seen how I can be...
Usually I will write one of my epic posts and by the time I post it there have been 2 or 3 new posts written since I started typing.
Adding to the SAI is also called Kingpin Inclination. basicly it is the angle of the balljoints as viewed from front or rear. A line through the ball joints will go to the ground hopefully throught the tire's contact patch. The SIA is not generally an adjustable item but is used to check for bent steering parts, bending a knuckle. When I do alignments the SAI numbers are generally ignored other then a quick glance to see of they are vastly different side to side indicating something is deeply wrong.
wesleydax
wesleydax
Just got the caster checked and i was wrong on what i have now. with 6.25 bushings i have 0 on the pass side and +1 on driver side. Would 5 degress with out bushings be good? i could then go with 2 degress have 7 and a desent drive line angle????? I should have had the work done last year when i priced it, i called the shop and they now want 500.00 to rotate them. Im thinking of rotating them this week myself, i have all the equipment.
JohnJohn
Richmond
If you turn the outer C I have some math that may help you.
D44 axel tube total circumfrance in inches= 8.5828
8.5828=360 degrees
1 degree = 0.023841111 inches
Multiply the degree of change you want by 0.023841111
will give you the inches you need to rotate.
As an example a 9 degree change will move the outer C about 1/8th of an inch or 0.21457 inches.
Double check my math before you go for it but I hope this helps.
wesleydax
wesleydax
John thanks for the math figures. i will double check before i start. hey if i take some good pictures of before during and after yal think it would be worth posting.
wesleydax
wesleydax
before i weld this thing back up see if im thinking right. with 7deg bushings i am at 0 caster. so without the bushings it would be -7. now if i set it up on the stand at -7 and roll the knuckle backwards to +5 and use a 2deg bushing it should put me at +7 after everything is back together. right??????
Remember that to get zero offset bushings you're going back to stock rubber with no retaining lips. If you want to stay with the modern polyurethane you're getting a minimum of a 2° offset. So factor that into your equations.
Unless someone is selling a zero-offset poly bushing I'm not aware of.
Of course, you can also tweak things a little bit by reversing the poly bushings to give more negative offset rather than positive. Hopefully you don't have to go there though.
Sorry, just re-read your post and you already talked about 2 degrees. I only saw the zero comment.
The answer is "yes", your figuring and factoring should be correct.
Just to make sure our wording is consistent though, you're talking about rotating it back a total of 10 degrees to get to the +5 mark, correct?
Whatever. You're thinking correctly that things are just linear and you make up what you're losing then add what you need.
wesleydax
wesleydax
Rotating it back toward driver a total of 12deg. This makes it +5 then when I add 2deg bushings it will be at +7. ????
You can get 0° poly bushings. Take a set of 2° (most even meat on both sides) and install one end backwards. Both offsets on the top or bottom.
wesleydax
wesleydax
got it done. ill report back how it does. probley be next week, sandblating all the parts and powder coating with all new joints, seals and bearings.
wesleydax
wesleydax
got to the alingment shop today everything turned out good. caster wound up being +6. it was a little work but not bad. thanks for all yals help. now to replace the stearing box.
JohnJohn
Richmond
so how does it drive with more caster?
Did you wind up turning it back 12 degrees from stock and using the 2 degree positive caster bushings?
wesleydax
wesleydax
drives better. im in the process of installing new steering box. havent driven it alot. Yes i turned it back 12 degree from where ford put it and went with the 2 degree bushings.
Congrats on getting it done so efficiently and nailing a +6 reading to boot! Nice job. All Broncos should be that lucky.
Hey Crawdad. Just saw this again after re-reading the thread.
Yes, you're right on. Based on the image on page 1, his angles are steeper than is desired. A dropped pitman arm and bracket (or riser) would be called for.
The angles aren't even exactly parallel either (close, but not on the money), so a little tweaking or careful selection of components to make them as close as you can get them would be beneficial too.
With his 3.5" suspension lift, he would usually benefit from both.
wesleydax
wesleydax
I got it back on the road today and it drives better than it has in years. i put a new steering box from duffs on it. big improvment. I put the drop bracket on and a drop pitman. first time in 20years you can fiddle with the radio while driving ;D. It will center itself up great after a turn. it has been alot of work but has been totaly worth it. now i can drive it to townsend in april. A big Thank You to everyone who has helped me figure this out.
