I am wondering if anyone has moved and mounted the hydroboost/master cylinder assembly straight over the inner fender? Not using an angled bracket, or that eBay bracket that is straight but sets the assembly out. Mounted directly to the firewall.
I've seen that some people keep it in the same location as stock on the firewall, but that it is very close to the engine. I have a 351W block with EFI so I don't think there will be enough room to get to the headers and whatnot.
Here is the plan:
Looks to me like it will work, but it would be nice to know if anyone else has done this before.
Thanks!
Here is the plan:
- Move the brake pedal assembly to the other side of the divider; between the divider and the column
- Remove pressed-in bushing on brake pedal by beating it with a BFH (done)
- Weld pedal to new, longer bushing that spans the section the clutch sits in
- Add a second lever arm to the bushing where the clutch pedal would be that has the pin to attach to the hydroboost
- Move master cylinder mounting hole over 5.25" towards driver and put hydroboost there
Thanks!
