MP3 player / audio Q's
cisco
instead of wiring a new stereo into the truck, adding speakers, etc. i was thinking of hooking up some sort of MP3 dock with speakers - all hidden inside a console.
wondering if anyone knew how i coudl wire a couple of speakers or the dock into the battery?
ideers appreciated!
Kidney
Hmmmm...I might be missing a few things here (or it might not even work) but, you could......
Buy a small amp and wire that to your battery. Run a couple wires to your speakers. Run a RCA cable with a small headphone adapter from the headphone jack on your MP3 player to the RCA cable input on the amp. You will need to run an on and off switch on the power line b/c you wont have a remote cable to turn off the amp like you would if you had a regular stereo. I'm not sure how you would control the volume. I would only guess that the voulume control on the Mp3 player would work. Amp's can be found much cheaper. I just picked this one b/c it's 80wx4.
RCA cable
Amp
Amp kit
Madgyver
Bronco Madman
I just bought a hardwire kit (Pioneer #CD-ID100) to wire into my Pioneer Head Unit to plug and play my new Ipod. I have been using the Airplay2 (FM Transmitter) to play music from my Ipod into the truck sound system or any other radio. You really need a clear FM channel but it works pretty damn cool!!! You could tune all your radios to the same station that the Ipod is playing and it will pick it up.
C
cisco
nice!
gonna see what i can squeeze outta my budget for christmas..
whatever i end up doing, ill try to take a lotta pics.
eb66to77
Bronc'Ownly
NOVA
RCA cable
Amp
Amp kit
I agree with Kidney. This can be done for those who have stock am radios and want to keep them unmolested. The RCA inputs are also called "low level inputs". I would run all of this off a relay also.
KJHill
Central WA
If your going to run wires from the MP3 via the headphone jack to the amp you will have some issues unless the amp has line level inputs. There is an adaptor to convert line level to RCA type inputs (pre-amp). Check out Crutchfield for all the goodies. Lots of possibilitys out there. :p
JaxLax
Jacksonville, FL
to put in a dock, that is presumably wired to run off a house AC current, you will need to be careful how you wire the power considering your truck is DC.
if you are going to try and use a docking station as a whole, it's going to be difficult to find a way to get good sound if you wun it through the dock speakers (as in one unit)
your best bet is go the route Mad talked about. getting a pre-built one to add on to your existing stereo.
other than that, perhaps there is an Ipod forum you could search and see if it's already been done.....enough people own those darn things, somebodies done it....
as for me, i just got a cd head unit and changer that plays mp3's for mine. with 5 cd's loaded of mp3's (that will most likely be compressed cd's anyways) i should have around 1000 songs easy...i mean how many different songs to you listen to on a daily basis that you need more?
ipods are nice, i'm not bashing them, but i would never carry one around. I carry my laptop with me to class 4 out of 5 days a week, so an ipod is useless. plus mine plays movies on a screen that isn't 2 inches ;)
