MSD Ignition question
figo40
St. Louis
I was going through some boxes in the garage and found an MSD 6a unit I forgot I had. I was looking through the instructions and can't really figure out which application is correct. I have a stock 302 with I assume the stock distributor. anyone have any insight on how to install the unit?
The diagram is for the later Duraspark electronic setup. You have that style cap and rotor, but obviously still have a points type distributor evident from the single Black wire running straight from the distributor to the ignition coil.
The advantage, especially for a points type ignition (if yours is compatible, which I believe it is) is that you will get a larger spark of a longer duration, as well as multiple sparks per cycle (3 vs the 1 of a stock ignition).
The benefits of multiple sparks are not as pronounced sometimes, but the worse your fuel delivery is dialed in, or the less efficient your combustion chamber design is, a multi-spark setup can benefit you anyway.
The better/bigger/badder/longer spark is going to help burn the fuel better in the combustion process. Let's you play around with carburetor jetting (leaner or richer) and still burn most of the fuel.
It's probably minimal horsepower and minimal fuel economy gains, but you're likely to still feel a difference by the seat of your pants.
Lots of members here swear by MSD products, while an equal number swear at them. Too many failures to ignore, but not all have had those issues. I've never had an MSD product fail, but I'm not using them on everything, so maybe not as good a judge as others.
Personally though, I'd run it since you own it. Be a fun experiment to see how things feel afterwards.
gr8scott
[YOUTUBE]k0ig-VRVMuE[/YOUTUBE]
00:35 - 01:13 shows the spark the MSD produces.
Semi-hack - when running one of these boxes would there be any benefit to running hotter plugs?
FWIW, i run Trick-Flow heads that use modern style 14mm plugs. Been running mine since last
November without any problems.
figo40
figo40
St. Louis
Thanks guys, Yes Paul I do have a standard points dizzy, There was a reason for the cap when I installed it but that was a long time ago and I've forgotten now.
Might have been just to get the better plug wires? That's why I did mine originally. Got tired of yanking terminal ends off of the old style wires when I was messing around.
broncnaz
The only real benefit of running one is you may get a little better idle especially on a poorly tuned engine. More or less what more stock ones are. Since you have it you may as well run it. Points will still be a limiting factor tho as they wear timing changes.
But its really uneeded unless you have a high compression engine even then its probably not that big of a benefit, A stock or really any ignition pretty much only puts out what is needed to jump the plug gap. You'd see more gains by just ensuring your advance curve and total timing is optimized.
John Marinan
Durango CO.
Having had 4 of these analog boxes fail I have some knowledge of what to look for. Three of these were the potted model sold as 4x4, and Marine. All four of them gave me a little warning. The vehicle would just not start for no apparent reason, then a few minutes later it would. Sometimes giving it a good tap with a wrench would make it come on.
It will happen a few more times then it's done, usually at the worst time. After the first one failed MSD sent me a new one, it failed, so I removed them all from my other vehicles and kept them as spares. I tossed the last one this winter. So if you use it remember how you wired it so you can remove it when it stops working at 11,000 ft.
I also had a blaster coil die just driving down the road, luckily it was on a road with a shoulder. I would have to say that with MSD always carry a spare!!
gr8scott
The new ones are digital. Not saying they won't fail, just saying.
I wired mine with Weather Pack connectors, and its paired with a MSD Ready-to-Run distributor. If it ever fails,
I re-pin 3 wires to bypass the box and I'm on the road again. I've had a Blaster coil fail while still in my yard.
I carry a spare one now.
