- Jun 11, 2004
- 11,879
This thing has a mind of its own it seems. Very touchy to working around with the maps and uploading stuff. It will run fine one second, then it starts doing weird shit the next time I try and run it. Frustrating so far. Also, the damn thing still won't go into closed loop. I am getting voltage from my O2 sensor, I have verified that my IAC is working, RPM signal is coming through. I don't know what is going on. Going to contact Holley support.
Congrats Devin! About time eh?;D
Were you talking about the closed-loop idle control? (which is always active if engine running) or the closed-loop modification of injector pulse, whihc only kicks in if the coolant temp is above the threshold (mine is at 180).
That idle control is one picky pesky son of a gun to get right. Too daggone many variable involved even for getting the warm idle performance to act right..worse when you include the cold-start and below tem parameters thrown in. I can tell you that I've spent far more tuning time on that danged idle control than with any other factor.
That 'delayed start' behavior is typical Holley defaut setting in the ECM...it can be tweaked too.
