My Build, 1975 2-into-1
old 71
Looking good Reynard ,
I feel your pain, I'm trying to assemble the bronco in a box , lots of two steps forward and one step back . Learning as I go . Your build is coming along nicely , won't be long now can't wait to see the finished product. Keep up the good work.
Dale
reynard101
reynard101
Thanks Dale. It's been slow going lately. I'm hoping to make good progress over the next few months.
My major goal is to have a running Bronco for the 2015 AZ Bronco Stampede.
reynard101
reynard101
Cut fenders
reynard101
reynard101
Started on hydro boost. Upgraded explorer power steering pump last week with super duty internals.
reynard101
reynard101
Ghetto-booty fab hydroboost socket. Only needed to take off the nut once.
reynard101
reynard101
Little more hydroboost. It's close.
old 71
Coming along nicely , on the down hillside of things now keep up the good work.
Dale
reynard101
reynard101
Mix of Explorer and E series brackets. Saginaw pump and OBA.
Trimmed the bracing out between on the AC mounting pad. Also had to trim the valve cover. Lots of trimming but it fits. Needs an idler pulley
reynard101
reynard101
Stock Explorer tensioner on alternator bracket. Added another idler pulley...
Please note the custom radiator hose holder.
Idler, needs to be shimmed slightly.
Passenger side explorer tensioner.
reynard101
reynard101
Getting closer to moving on it's own.
Need to bleed brakes (more) and hydroboost. And a little tuning. And fill axles with oil.
video...
reynard101
reynard101
SOOOOOO close to test driving. Making sure all the little stuff is done. Don't want to hurt anything (including me). Hoping to make test drive by Thursday.
Rear explorer calipers were on the wrong side, switched and the brakes bled easily. Hydroboost took some effort to bleed. I also made a band-aid extension on my Saginaw pump, like this...
images
Trying to get it above cooler and add extra capacity. It seems like it's bled, no whining. Still need to lean out carburetor, those unburned hydrocarbons are harsh.
reynard101
reynard101
Bronco is ready for start up and test drive. Tonight after work. Video to follow!
No front fenders or grill for test drive.
SSDDBRONCO
Los Angeles
I noticed in the beginning you started off with an efi motor. What did you change over to carb or bolt on efi, like msd or holley?
reynard101
reynard101
Time and money. With this engine I would need a custom tune as well. EFI will happen sometime down the road. Some of the TBI systems look tempting too (MSD and FAST 2.0), might go that route.
Using a Quadrajet turned backwards on a Edelbrock intake.
Quadrajet is claimed to be one of the better off road carbs, aka hillbilly fuel injection.
reynard101
reynard101
Rebuilt box. Ported. Benchwork Steering.
reynard101
reynard101
Cage work at a local shop, Bent Fab. Guy (Paul) is a miracle worker, considering my less than average body work.
reynard101
reynard101
Few more pics. Cage done. Mastercraft seats.
