mhinchliffe
- Joined
- Dec 21, 2018
- Messages
- 110
Ok - I had finally a few spare moments to go out to the shop to study and formulate a repair for my 49 year old sloppy door hinges. The following is what I did.
Removed the passenger side top hinge (the worst one)
Pressed pin out in 20 Ton shop press
Finished removing pin with drift pin
Marked each half for reference so I didn't mix things up
Brass wire wheeled the pin
Media blasted hinge pin hole in door side hinge
Measured the pin diameter - 0.281"
Measured the hole I.D. of the A pillar hinge - 0.2815" and 0.2805"
Measured the hole I.D. of the door side hinge - 0.297" and 0.2965"
Filled the I.D. of the door side hinge with weld top and bottom
Located the center
Drilled a pilot hole utilizing mill
Drilled on size hole for pin - 9/32 or 0.28125"
Aligned match marks
Installed pin into hinge
Reinstalled hinge into door and pillar
Now working through realigning door to body
Located the center
Aligned match marks
