nathan.hall1
I have been reading threads and gathering parts for awhile now. and yesterday I finally installed it.
Well phase 1 anyway...
a few years ago I upgraded to power brakes and bought the booster and angled bracket on EBay Regrettably... my MC leaked and I replaced that and the booster I think was weak. when I first got it, it was great but over time it has been getting harder to brake, so I think it was going out.
luckily the angle bracket is fine...
Also I will mention when I upgraded my power steering a few years ago I am running a single return Saginaw on a adapter bracket I got from one of the Vendors, I am thinking WH.
so I got a Hydro boost unit out of a 95 GMC safari AWD Van. so I grabbed everything including the MC and Prop valve which I have plans of using.
But yesterday I just had time to do the Hydro boost portion and not change out the MC and all that comes with that. that will be my next day off...
So what I discovered that the rod that came of the Astro Unit was the perfect size to be threaded so I was able to take the end off of the Vacuum booster and thread it on and now the boost unit bolted to the Angled bracket and was hooked to the Pedal.
I was able to get it plumbed in with the help of a google search and routing instructions. I got the Fittings metric fittings from EBay and the 90 degree AN fittings locally as well finding a local hydraulic shop for hoses I added a cooler I found on Amazon under the radiator. and bled the system and presto stopping power. I bolted old MC to it and it was ready to go.
I used this diagram
I took it for a test drive and almost put my self thru the Windshield. it stops and handles great.. although too hard of braking will lock up all 4 wheels... so...
my Phase 2 will be installing the New Astro MC (used the one from junk yard as a core) with its accompanying Prop valve. I have read that this set up works well we will see.
I always forget that I'm a contributor so I can add photos with out PhotoBucket old habits die hard I guess..
Future plans I am gather parts for a serpentine setup on my 351 so I will get a dual return Saginaw to eliminate my T
I used this diagram
