I was going to look up some of those threads about oil consumption through the PCV system and add some thoughts. But since you brought yours up, I’ll just add some here!
It may have been covered before, but I can’t go back through at the moment. What oil pan do you have?
How many quarts of oil are you running?
Is this a stroker engine? And if so, was it done by machining the existing crank, or is it a special crank with larger throws?
If a non-stock pan, which one is it exactly?
No matter what, are you going by the number of quarts, or by the check marks on the dipstick?
Maybe none of this pertains to any of these oil consumption discussions, but I’m wondering if overfilling the oil is causing aeration and more oil vapors to be tossed up into the system where it’s captured by the PCV valve.
Excessive oil in the air would seem just like blow-by to a vacuum source.
Just thought I would bring it up for discussion.
