- Jul 30, 2001
- 14,902
This is with lowering arm at frame pivot point.Rotating the axle back( that’s what lowering the arms does) increases caster for sure.
Caster is the question.
Lower the ride height will accomplish the same thing, rotate axle (top) towards the rear, giving you more caster. After building several broncos I've come to realize that you don't need to be high for the bronco to perform on the trails. Make it work on a low stance and you will avoid these issues.
Bumpsteer?
that's another topic.
