GM Saginaw box.
The only mod that I can think of is a slight variation on the hole spacing. If it was done right, it should be fine, but Ford used internal braces to strengthen the area for the clamping forces.
At the very least though, a little beefing up would be in order for a conversion such as this.
Should be easy enough to see if any plating, or reinforcement of any kind, was welded on to the frame.
Your frame rail was actually notched for the box, and I do see a tube welded to the bottom for the lower bolt, but you'll have to inspect it for any other goodies.
You might also have a helper work the steering back and forth while you watch to make sure there are no cracks or excessive flexing going on in that area.
i can remember talk about stroope doing this early on before there was a stock power steering box. might be something to check out.
looks pretty stroppe-ish to me. is that a cooler mount under the radiator i'm seeing in the pic? the body mount mod is very reminisant as well.
Weren't some of the Stroppe PS boxes painted GM orange? Looks like this box may been orange at one time...
Looks Stroppe-ish to me as well
Is the truck an automatic? Are those brackets off the crossmember rements of a Stroppe trans cooler?
My understanding is that not only did Stroppe do trucks that were drop shipped to him but he would also do trucks that were bought elsewhere and brought in to him. Hense a non-Stroppe DSO.
No fair
The rest of us want to know as well.
