Bronco73
i have two full size 78/79 d44 axles. since they don't seem to be selling well i figured i would look into cutting them down to fit and eb. i am hoping to get this done cheap enough to sell them. i recall a post discussing but would like some details on this proceedure. i tried searching and even went through the tech section.
i've read only 5 inches needs to be cut out of the pass. side of the axle. if so does the radius arm mounts line up correctly with the eb set up? does the d44 axle tube have to be turned down in a lath in order to press it back in the center section or can it just be cut and pressed back in? how much force or tonage does it take to press the axle tube out and in?
has any one every mounted the full size bronco radius arm mounts onto an eb and used the full size bronco radius arms?
